20 Most Recent Summit SPWD1800 Questions & Answers
SPWD1800 Manual
Summit SPWD1800 | Uploaded on Dec 24, 2017
It means something is wrong with door lock mechanism.im currently having same problem.
Summit SPWD1800 | Answered on Mar 03, 2017
drain the water off by placing the outlet pipe near the floor into a bowl then unplug the machine take the top off, push the drum to the rear and using a small screwdriver remove the door lock and replace from the manufactures website not forgetting to remove and replace the wires on the lock eric
Washing Machines | Answered 5 minutes ago
go to the manufactures website and download the user manual and look in the trouble shooting guide eric
Washing Machines | Answered 15 minutes ago
call the local washing machine repair person for a quote as it seems you've covered all the options eric
Washing Machines | Answered 16 minutes ago
unplug the machine remove the rear cover locate the water pump see if you can rotate the cooling fan as sometimes a button or other debris blocks the pump, remove the water pipe and clear the blockage replace pipe and run machine if there is no blockage then the water pump may need replacing from the manufactures website eric
Washing Machines | Answered 19 minutes ago
sorry we can not fix what we can not physically see . but would suspect you pulled an internal connection loose .
Washing Machines | Answered 4 hours ago
could it be that the hot line is plugged with dirt or frozen , check the screen in the hose end .Hot lines always freeze first
Unplug machine, wait 10 minutes. Make sure water supply is turned on. Then plug machine back in. It should be reset and ready to run.
Take it out and clean it. There is most likely a build up of softener in the syphon tube
Washing Machines | Answered 9 hours ago
Summit SPWD1800 Logo
7 questions posted
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Summit Washing Machines
Most Popular Question
error 1 sign summit spwd 1800
  • Washing Machines
