20 Most Recent Hamilton Beach 45237 Stay or Go Thermal Coffeemaker Questions & Answers
HOW DO I GET A MANUAL & GULDE BOOK
2/8/2015 11:08:13 PM • Hamilton Beach... • Answered on Feb 08, 2015
How make coffee in hamilton beach stay or go 45237
The Use & Care Manual for the Hamilton Beach Stay or Go Thermal Coffemaker 45237 can be found here:http://useandcares.hamiltonbeach.com/files/840168001.pdf
4/29/2012 12:25:31 AM • Hamilton Beach... • Answered on Apr 29, 2012
2answers
Hamilton beach flexbrew. Say “Fill H2O” but is is full. What do I do?
I was able to fix this:1. Remove top cover2. Remove grate, one screw3. Dump water4. Clean water sensor probe (silver colour, bullet shape, approx 1/4" long), use a small flat screw driver with paper towel to remove any build up.5. Plug in and test until it works.if you get it to work again, that would be a good time to run the vinegar solution through.
3/5/2024 4:33:36 PM • Hamilton Beach... • Answered on Mar 05, 2024
Hamilton Beach HSDCU60C coffee maker. E3 error in the coffee maker.
Question edited for clarity. Question moved from Washing Machines category. Help in the link https://www.google.com/search?q=Hamilton+Beach+HSDCU60C+coffee+maker.+E3+error ..
1/25/2024 9:15:21 PM • Hamilton Beach... • Answered on Jan 25, 2024
Hamilton Beach FlexBrew. Say Fill H2O but is is full. What do I do?
These machines needs regular dealer service, but of course they don't tell you that when you buy them. Contact their support and request warranty assistance. Some ideas here https://www.google.com/search?q=hamilton+beach+coffee+maker+says+add+water
FlexBrew® Coffee Makers
Hamilton Beach https://hamiltonbeach.ca > flexbrew-coffee-makers With a FlexBrew® coffee maker in your kitchen, you'll enjoy maximum brewing flexibility. You can brew into a cup or travel mug, enjoy up to 10 oz. of coffee ...
FlexBrew® Trio Coffee Maker (49902C)
Hamilton Beach https://hamiltonbeach.ca > flexbrew®-trio-coffee-mak... Enjoy the versatility of 3 ways to brew with the Hamilton Beach® FlexBrew® Trio Coffee Maker. Brew a single cup in about 90 seconds with a single serve pod ... $159.99 · ‎ In stock ..
1/10/2024 12:42:08 AM • Hamilton Beach... • Answered on Jan 10, 2024
How to determine the correct Thermal switch replacement?
48.8889 C is equal to 120 F
10/13/2023 3:18:36 PM • Hamilton Beach... • Answered on Oct 13, 2023
Hamilton Beach coffee grinder model 80393. Blade is really loose, how to tighten please?
Question edited for clarity. How about a new grinding cup for $10? https://hamiltonbeach.com/removable-grinding-chamber-990099602 There seems little support and no parts diagrams that show how the parts fit together. There are a couple of videos that may help as all models work to a theme where the grinding cup is concerned. Manual and Hamilton Beach contact details https://www.manuals.ca/hamilton-beach/80393/manual ..
8/25/2023 5:21:46 PM • Hamilton Beach... • Answered on Aug 25, 2023
The coffee dispenser bar isn't working in my Hamilton Beach coffeepot 47900. Nothing comes out! Can I fix it?
There are a few possible reasons why the coffee dispenser bar on your Hamilton Beach
  1. Check the water level in the reservoir. Make sure that there is enough water in the reservoir to brew a full pot of coffee. If the water level is too low, the coffee dispenser bar may not work properly.
  2. Clean the coffee dispenser bar. Over time, coffee grounds and other debris can accumulate on the coffee dispenser bar, clogging it and preventing the coffee from flowing properly. To clean the bar, run a solution of equal parts water and vinegar through the coffeepot and then rinse it thoroughly.
  3. Check the filter basket. Make sure that the filter basket is properly seated in the coffeepot and that it is not clogged with grounds. If the basket is not properly seated or is clogged, it may prevent the coffee from flowing through the dispenser bar.
  4. Check the gasket. The gasket is a rubber seal that helps to create a tight seal between the carafe and the coffeepot. If the gasket is damaged or worn, it may cause a leak and prevent the coffee from flowing through the dispenser bar.
If none of these troubleshooting steps resolve the issue, it is possible that there is a problem with the coffeepot itself. In this case, you may need to have it repaired or replaced.
1/7/2023 8:26:12 PM • Hamilton Beach... • Answered on Jan 07, 2023
2answers
My Hamilton beach flex brew says add water when full and will not work
Push "Carafe" button.
12/23/2022 9:06:23 PM • Hamilton Beach... • Answered on Dec 23, 2022
Hamilton Beach coffee grinder 80365
Try tapping the other way. You may have unseated the motor's carbon brushes. or Send it back under warranty. https://hamiltonbeach.ca/customer-service ..
9/4/2022 9:55:24 PM • Hamilton Beach... • Answered on Sep 04, 2022
Hi, I just purchased a Hamilton Beach Brewstation . After brewing the coffee it sounds like the coffee that is being kept warm is boiling ? What is causing this ? It’s very loud and doesn’t seem normal ??? Please let me know? Ty
Mine does the same. Very annoying and the unit is 3 months old. I cleaned the unit yesterday and no help. I'll call HB today and see if they can help.
4/1/2022 12:31:19 PM • Hamilton Beach... • Answered on Apr 01, 2022
How do I know when my Hamilton Beach flex brew coffee maker is turned off? No lights appear to indicate on/ off
Normally there are no lights which does signify off. To check, disconnect from the mains electricity supply for 5 minutes and plug back in. https://www.google.com/search?q=hamilton+beach+flexbrew+coffee+maker+manual ..
12/2/2021 5:56:43 AM • Hamilton Beach... • Answered on Dec 02, 2021
2answers
Hamilton beach flex brew has turned on twice now with no program set. Very Dangerous. What can we do?
Report this potentially dangerous defect to Hamilton Beach.
12/1/2020 3:46:34 PM • Hamilton Beach... • Answered on Dec 01, 2020
My Hamilton beach 80335R grinder does not turn on. Only used it 3 times. Outlet is fine (tested it) Was a Christmas present.
Take to the store where it was purchased and have it replaced. Warranty Get receipt.
1/9/2020 8:54:02 PM • Hamilton Beach... • Answered on Jan 09, 2020
2answers
I have a hamilton beach coffee maker and the tank seal has came loose. I got it taken apart but now I can't get the seal in place. Someone please tell me there is an easy way.
Easy way is to get online or go down to your favorite store and buy a new coffee maker.
3/5/2019 4:46:59 AM • Hamilton Beach... • Answered on Mar 05, 2019
2answers
Just had my hamilton beach 49979 coffee maker delivered last night. Water heats up, bubbling noises are heard, then the light goes off, with nothing else happening. Any ideas?
Hello, Larry - Since your coffee maker is new, and most likely covered under warranty, contact the seller and arrange to return the coffee maker for a replacement which works properly. You will probably have to provide a copy of the sales receipt to verify the date of sale. If you purchased your coffee maker through a bricks and mortar store, I suggest you return it to a nearby branch of that store so you do not have to pay the cost of return shipping. Best wishes.
12/24/2018 5:12:23 PM • Hamilton Beach... • Answered on Dec 24, 2018
Hamilton Beach 45237 Stay or Go Thermal Coffeemaker Logo
4 questions posted
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Hamilton Beach Coffee Makers & Espresso...
  • Hamilton Beach Coffee Makers & Espresso...
Most Popular Question
get manual amp gulde book
  • Coffee Makers & Espresso Machines
