hotsych not working when hooked unto usb. my system is xp. how can i solve this problem. my clie...
(More)
hotsych not working when hooked unto usb. my system is xp. how can i solve this problem. my clie doesn't update new information into my desktop.
recently i tried to hotsync my clie peg-sj33 and its showin a message that the usb port is in use by...
(More)
recently i tried to hotsync my clie peg-sj33 and its showin a message that the usb port is in use by another applicaton;i ve tried installing the handheld in two other different pcs and still its showin the same message. i ve even installed the cd several times on my pc as well. but i m still getting the same message. i am unable to to hot sync via USB port. please advice on what i should do.
dropped my pda screen is on it will hot sync] nothing shows on the display is there a loose...
(More)
DROPPED MY PDA SCREEN IS ON IT WILL HOT SYNC] NOTHING SHOWS ON THE DISPLAY IS THERE A LOOSE CONNECTION AND IF SO, HOW DO i REPAIR IT
I have lost the CD that came with the SJ33. Is the software that was on the CD available as a...
(More)
I have lost the CD that came with the SJ33. Is the software that was on the CD available as a download from the Internet? Thank you
pen will not work on screen on the right side. a fine crack in bottom of screen on right side. Is...
(More)
pen will not work on screen on the right side. a fine crack in bottom of screen on right side. Is this why the touch screen won't work. on the right side. I have another sony clie sj33 that quite working. Can I remove the screen from it. The one that quite working, could this be the battery. It says error and won't open.
I had the same hand held that died for me recently so I bought a new one from ebay. It hot sync...
(More)
I had the same hand held that died for me recently so I bought a new one from ebay. It hot sync fine. programs open the right size fonts but program icons very small. How can I enlarge them,
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well...
written by PCTServices
select start ---- select settings ------- select connection----- select connections Now Select Add a new modem connection Connection name Give any...
written by billa vimal
I write this tip for Palm Pda's but it is valid for many other brands of pda's and phones. First things to try is a normal reset and then a hard...
written by Ekse
Lock code:
1. 5 digits, Used to prevent unauthorized access to certain functions on the phone
2. Where: Tools > Settings > Security >...
written by Shilon
Hi, Got this great instructions from - www.rapidrepair.com. Tools required: Small Phillips Screw Driver Small Flathead or exacto razor Safe Open Tool ...
written by merryAnn
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
