20 Most Recent Neff B1861 Single circotherm super Stainless Steel Electric Oven Questions & Answers
have to call service tech
Neff B1861... | Answered on May 17, 2010
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Neff B1861... | Answered on Dec 29, 2008
You have a major short if if trips the power supply to your home, immediately get a licensed electrician to check out the cause of the short. I figure it is probably a loose wire for your oven in your breaker panel, but it is not worth burning your home down or possibly hurting yourself to not call an electrician.
If you decide to fix it yourself, trip the breaker to the entire house before you open the breaker panel. You do not want to become part of the typical 200 amp power supply in most home breaker because of a loose wire in the breaker.
I have seen wires burn off of the breaker near the individual breaker and fall down inside the breaker panel and be in touch with the breaker panel.
Neff Ovens | Answered on May 21, 2019
I moved you to NEFF oven out of wrong forum Computers.
Neff Ovens | Answered on Apr 21, 2019
Turn the power off for 10 seconds, after turning it back on the first thing it will do is prompt you to set the language, date and time.You can visit www.neff-home.com/uk/service/manual
Neff Ovens | Answered on Mar 16, 2019
Was old bulb tested after removal? Can you please check the switch?
Neff Ovens | Answered on Feb 27, 2019
The regulator on the main control board has failed.
Neff Ovens | Answered on Feb 22, 2019
ASK GOOGLE OR NEFF WEBSITE TECH SUPPORT
Neff Ovens | Answered on Feb 17, 2019
Neff B1861 Single circotherm super Stainless Steel Electric Oven Logo
Popular Tags
7 questions posted
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
oven bulb
  • Ovens
