20 Most Recent Neff B1451 Single circotherm plus Electric Oven Questions & Answers
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Neff B1451... | Answered on Apr 28, 2013
If you are struggling to get the lamp cover off in the far right top corner, try wearing a pair of rubber gloves to get a better grip and you need to turn it right to left ad you look at it, if it still will not move, contact Neff Customer Service and they should sent you out a removal tool free of charge 0844 892 9002
Neff B1451... | Answered on Nov 23, 2011
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Neff B1451... | Answered on Oct 04, 2011
It's possibly the switch, I would first check your connections to the new element, check there is continuity in the new element (just because it's new doesn't mean that it's not the problem). Check that the clock is set and not on auto. It could also be the oven stat, does the indicator light come on above the temp knob (if it does this is a good indication that there is power to the element).
Use the link, look at page 4, check there is continuity across part 057895 (next to fan). page 2 make a visual check of parts 167546 and 183598 for blows on the board or scorching on the switch.
Hope this helps and that it is something simple, best of luck.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=B1451W2GB%2f01&ESHOPTYPE=S
Neff B1451... | Answered on Aug 24, 2010
Tip
Common heating faults with Neff B1451 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1451 Single circotherm plus...
Neff B1451 Single circotherm plus Electric Oven Logo
26 questions posted
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
change bulb in o ovenneff
  • Ovens
