20 Most Recent Frigidaire 30 in. Electric Self-Clean Coil Top Drop-In Range Questions & Answers
I have a drop-in oven from frigidaire.I started the self cleaning process the door did not lock and the light keeps flashing,I dont know how to stop it and i cant use the oven at all.
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
10/16/2014 1:50:16 PM • Frigidaire 30... • Answered on Oct 16, 2014
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
10/15/2014 4:45:50 PM • Frigidaire 30... • Answered on Oct 15, 2014
Frigidaire Professional FPIC3677RF Induction Cooktop Won't Heat Up. Is there a Lock-out Feature We Don't Know About?
if you have read your manual stainless doesnt work but your cast should --check with a magnet if it doesnt stick pan wont work but notify company or manufacturer customer service of problem[s] since your unit should be under warranty
4/23/2023 7:26:35 AM • Frigidaire... • Answered on Apr 23, 2023
Cooling fan is not working on Frigidaire stove. Is it ok to use the cooktop?
If it is the fan under a ceramic flat top, no, because its purpose is to keep the control boards cool. If it is the oven fan, yes no problem.
1/29/2022 8:22:11 PM • Frigidaire... • Answered on Jan 29, 2022
2answers
Frigidaire ceramic cooktop and one element stopped working can I replace that one element
yes you can, look online for parts and prices, compare to local prices.
6/10/2019 1:53:25 PM • Frigidaire... • Answered on Jun 10, 2019
tip
Bad Electric Cooktop Dual Element Switch
Our Frigidaire Gallery electric cooktop dual burner would not work when either the single or double mode was selected. I did not have the electrical schematic available to use for troubleshooting the switch and initially was not certain if the switch or heating element was bad. In thinking about the situation, I deduced that the problem was most likely the switch being bad as it was highly unlikely that both elements of the dual element burner would be bad at the same time. I ordered a new switch, received it a few days later, and replaced it in about 25 minutes. Upon turning power to the cooktop on and trying the new switch, both elements of the burner worked as expected.
on Jan 04, 2019 • Frigidaire Cooktops
Our Frigidaire Gallery induction cooktop is 'locked'. How to unlock?
Press and hold the keypad with the padlock icon until you hear a beep. This should be about 3 seconds. This will toggle the lock on and off. I used the documentation for the Frigidaire FGIC3067MB to check this. On this model, the lock keypad is to the left of the Keep Warm keypad. https://www.frigidaire.com/Kitchen-Appliances/Cooktops/Induction-Cooktops/FGIC3067MB/ . The manual is here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205604en.pdf . The control panel is shown on page 5 and the lock function is shown on pages 6 and 9. I hope this helps. Cindy Wells
2/28/2018 11:05:40 PM • Frigidaire... • Answered on Feb 28, 2018
Center burner won't ignite
Try cleaning out the holes in the burner, specially near the spark.
10/15/2016 8:02:40 PM • Frigidaire... • Answered on Oct 15, 2016
BURNER WILL NOT LIGHT
Try cleaning out the holes in the burner, specially closest to the spark.
10/15/2016 8:00:13 PM • Frigidaire... • Answered on Oct 15, 2016
Burner won't turn off. stays in simmer mode
Good Afternoon Judy, thanks for your post! From what you have described the burner on your Frigidaire cooktop will not shut down and continues to run in simmer mode. I would suggest performing a reset on your cooktop and you can do that by disconnecting power from your cooktop for at least ten minutes. If that does not help alleviate your situation you may need to have a burner switch or control panel replaced and that is not a simple DIY job. If any electrical components need to be replaced I would recommend contacting a professional technician for proper repairs to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -OOS
4/13/2015 8:19:02 PM • Frigidaire... • Answered on Apr 13, 2015
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
2/3/2015 4:09:48 PM • Frigidaire... • Answered on Feb 03, 2015
Why doesn't our Frigidaire Gallery Cooktop stove display the oven temp?
It has a bad temperature sensor If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
8/31/2014 11:30:36 AM • Frigidaire... • Answered on Aug 31, 2014
I have a Frigidaire cooktop, model #GLEC3689EBB. We prepared a dish for supper, went into the dining room to eat. Something smelled hot and when we went to the kitchen, another burner was glowing red
Hello Friend, this is Z. Thank you for your post! Based on the symptoms you are describing it appears that your Frigidaire cooktop may possibly have a faulty switch or EOC (electronic oven control). This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
7/8/2014 4:53:01 PM • Frigidaire... • Answered on Jul 08, 2014
Have a gas cooktop that clicks even when the knobs in are in the off position
Good Afternoon Hon, I understand that your Frigidaire gas cooktop, model# FGC30S4ASA, is clicking even when the knobs are in the off position. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and listen for the clicking with the burner knobs in the off position. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
7/3/2014 8:41:16 PM • Frigidaire... • Answered on Jul 03, 2014
0answers
Weight
Be the first to answer 5/20/2014 3:49:44 PM • Frigidaire... • Posted on May 20, 2014Be the first to answer
FRIDIGAIRE COOKTOOP BIG BURNER GLOWS ON AND OFF VERY FAST NOT LIKE IT USE TO-IS IT THE SWITCH OR CIRCUIT BOARD PROBLEM?
could be either one. the best way to troubleshoot this problem is to get to the switch and use a circuit tester on the switched side with the switch turned on to see if you are getting any fluctuation in voltage. if you are getting a steady reading with the switch in the on position, you have eliminated the switch as being your problem, and would then be looking at a possible circuit board problem. hope this is of help to you
5/20/2014 3:17:04 PM • Frigidaire... • Answered on May 20, 2014
Frigidaire 30 in. Electric Self-Clean Coil Top Drop-In Range Logo
2 questions posted
Top Frigidaire Cooktops Experts
Mike Cairns
Mike Cairns
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Cooktops
Most Popular Question
drop in oven from frigidaire started
  • Cooktops
