20 Most Recent Sony VAIO RA826G (VGCRA826G) PC Desktop Questions & Answers
Beeps 6 times when turned on, monitor remains
Try the link below for an explanation of beep codes. https://www.pcmag.com/encyclopedia/term/38515/beep-codes
2/17/2018 3:27:27 PM • Sony VAIO RA826G... • Answered on Feb 17, 2018
Needs drivers for sony vaio ra826g
Try the sony website here: http://esupport.sony.com/US/perl/model-home.pl?mdl=VGCRA826G&LOC=3#/downloadTabYou just need to select your operating system.
7/6/2012 11:03:22 PM • Sony VAIO RA826G... • Answered on Jul 06, 2012
My Sony VGC-RA826G Desktop turns on and then beeps
Sounds like a memory error. Try pulling out one stick at a time until it is able to boot. Assuming, of course, you have more than one stick. If not, buy or borrow a new stick and try that. With 3 beeps the bad stick is likely to be in DIMM slot 1.
here is a description of beep codes for various BIOSes:
http://pulonangka.web.id/software/beep-codes-error-codes
9/3/2009 12:13:52 PM • Sony VAIO RA826G... • Answered on Sep 03, 2009
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Pci modem drivers and audio drivers
Check this Sony's website: Original Drivers Package
10/9/2018 8:31:43 AM • Sony VAIO... • Answered on Oct 09, 2018
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM • Sony VAIO... • Answered on Sep 30, 2018
0answers
2answers
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM • Sony VAIO... • Answered on Jan 22, 2018
My laptop has limited internet access. I've called
Hello - Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home. Perhaps the information here will prove instructive: https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM • Sony VAIO... • Answered on Dec 28, 2017
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
Ewwwwwww... no fun. You should try a "POWERED" 4 Port USB 3.0 Hub It's important that it's a "POWERED HUB" because you need the HUB to supply it's OWN power and not depend on your Apple E to provide power to your connected USB devices! The good news is they don't cost much: $8 on eBay Auction: 202096902632 Note that they include the power supply! Many other HUBS don't. Your HUB is even LESS if you pick on the USB 2.0. Version, AND YES, each HUB MUST have it's own power supply and that's just what YOU need. The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too. I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now. Anthony Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
12/2/2017 5:45:59 AM • Sony VAIO... • Answered on Dec 02, 2017
1My Sony VGN-UX230P has many
Gotcha... it MAY be a internal ribbon cable to your screen is loose (or not seated 100%) OR sometimes a cable one conductor inside the cable breaks and acts like a switch ~ providing a OK display sometimes ~ or not. A PC repair shop will take a quick look for you for X-Bux and IF it is a loose connector/ribbon cable they MAY be able to fix it for you on the spot... A decent camera repair shop may be a answer for you too? They are very familiar with tiny screws and display repairs. Be careful though and don't spend too much... I would not recommend you open it yourself because sometimes things go "boing" and tiny things go flying. Anthony
12/2/2017 1:49:22 AM • Sony VAIO... • Answered on Dec 02, 2017
2answers
Sony vaio onetime password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
11/22/2017 2:01:09 AM • Sony VAIO... • Answered on Nov 22, 2017
Sony vaio VPCEB43FD upgrade ram wont work
Try them in different order. I swear sometimes, they have a mind of their own!! Ohhhh, same can be said for USB devices. One port won't be able to install it, another port will have the driver installed by the time you clicked on it ??
9/28/2017 6:08:46 AM • Sony VAIO... • Answered on Sep 28, 2017
Sony VAIO RA826G (VGCRA826G) PC Desktop Logo
3 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
beeps 6 times when turned monitor
  • Computers & Internet
