the modem is a ce-fm4 fax/modem Can i buy a New one Some where? oh ya and when i turn on my zaurus...
(More)
the modem is a ce-fm4 fax/modem Can i buy a New one Some where? oh ya and when i turn on my zaurus it says replace memory backup battery. Please read the operation manual for directions. And i did but it did not help me.
I put in a new main battery and now the Zaurus asks the following: Do you really want to initialize...
(More)
I put in a new main battery and now the Zaurus asks the following: Do you really want to initialize the main battery [This will delete all main data ].What should I do to save the main data?
I have a factory reconditioned Zaurus ZR-5800 which is a spare in case my other unit stops working,...
(More)
I have a factory reconditioned Zaurus ZR-5800 which is a spare in case my other unit stops working, so it has had almost no use since having been reconditioned. However, I have kept it installed with good batteries, and I turned it on every once in a while. My problem is that last time I tried to turn it on, the screen remained blank. The touch screen and keyboard still beeped when touched, and the backlight works, but the screen remains blank. I tried changing the batteries and I tried changing the brightness on the screen using the keyboard, with no luck. Any suggestions?
I have a zaurus 5800 and memory cards for it. I want to transfer the content to my mac,...
(More)
I have a zaurus 5800 and memory cards for it. I want to transfer the content to my mac, blackberry and or iphone.
Batteries are new (both kinds) and have done both resets numerous times with the exception of...
(More)
Batteries are new (both kinds) and have done both resets numerous times with the exception of complete reset that would delete all entries, i.e., I press "N" when screen appears with yes, no question. Then it gives an on-screen message that says "working, please wait." but after it finishes, I still can't use the touchscreen or access anything. The only item that appears onscreen when I turn the unit on is my name and address. Initial start-up is not password-protected. Would appreciate any ideas since I have so much important info stored in it. I do have a Zaurus Partner app (never used) which came with a floppy disk so that I could transfer data from Zaurus to computer, but don't know if it would work with my computer that has XP. It's call a Zaurus Data Exchange Utility.
I have a Sharp Zaurus ZR-5800 PDA. When I press the Contacts tab, to the right of the screen, I...
(More)
I have a Sharp Zaurus ZR-5800 PDA. When I press the Contacts tab, to the right of the screen, I hear the familiar electronic sound (like a ''beep''), but my list of contacts does not display. I backed up the Zaurus, using Rupp-Lynx, because the Memory function indicates my contacts are still in the Zaurus--just not accessible. This seems to be a software issue. Any idea as to how I can see my contacts again?
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well...
written by PCTServices
select start ---- select settings ------- select connection----- select connections Now Select Add a new modem connection Connection name Give any...
written by billa vimal
I write this tip for Palm Pda's but it is valid for many other brands of pda's and phones. First things to try is a normal reset and then a hard...
written by Ekse
Lock code:
1. 5 digits, Used to prevent unauthorized access to certain functions on the phone
2. Where: Tools > Settings > Security >...
written by Shilon
Hi, Got this great instructions from - www.rapidrepair.com. Tools required: Small Phillips Screw Driver Small Flathead or exacto razor Safe Open Tool ...
written by merryAnn
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
1500 Castro St, San Francisco, CA 94114 | 415 8266678 | Website
Castro Computer Services provides computer har... Read More
Castro Computer Services provides computer hardware and software services for small and mid sized businesses in the San Francisco Bay area. We have both in shop and onsite services to expedite job completion. Companies that need qualified on call service technicians, whether on demand or on sched...
