20 Most Recent
LG WM3987HW Front Load Washer/Dryer Combo - White Questions & Answers
WM3987HW
There are two solutions to this problem. 1. The load of clothes is not balnced correctly in the drum/or you are putting too many clothes in the machine. 2. The bearings have worn and have given up. These bearings cost more than the machine too repair as it is a huge job, also, most "technicans" will rip you off. If it is option 2, I recommend buying a new machine(as you can't replace them yourself without all the expensive tools). Buy a machine with the longest warranty and a descent brand. Don't be fooled by buying machine made in ITALY(eg. ARISTON) as Italy make junk these days, they only ASSEMBLED in Italy. Most parts are from Slovenia etc. Made in China is fine with washing machines. best bang for your buck is either SAMSUNG or LG frontloaders.
CHEERS.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
