20 Most Recent
LG WT5101HV 4.5. CU. FT. ULTRA CAPACITY TOP LOAD WASHER FACTORY REFURBISHED FOR USA Questions & Answers
Why does the UE come on ,on the cleaning cycle
The UE error or fault code indicates that the load of clothes is unbalanced. Try rearranging the clothes. Also, if you are only washing a few items, you may need to add a few more to allow the tub to balance. Also, check to be sure the machine is level and that all four feet are touching the floor. Tighten the locking nuts on the feet to lock them into place. If that doesn't seem to be the problem, either the suspension rods or shock absorbers may be broken or worn out.
LE appears on top loading washer wt5170hv
The LE error or fault code is to indicate that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
I have got a front
Is the washing machine giving off a hot machine oil smell or making a grinding noise when the tub is turning? I've had to replace the drum bearings several times on LG front load washers. The first sign that the bearings are going are loud noises when the drum is spinning and eventually the hot machine oil smell. The bearings can be replaced but they usually last only 6 months to a year. The bearings are put on with a press at the factory and unless you are very accurate, you won't be able to get them on exactly straight and they will wear out quick.
10/27/2023 10:07:56 PM •
LG Washing...
Answered
on Oct 27, 2023
