20 Most Recent Hobart Dishwasher Am-14 Commercial Dish Washer Questions & Answers
2answers
I have a Hobart am 14 with a new pump motor drawing high amps
Search Results
    Dishwasher Electrical Problems - Chapter 6 - Dishwasher ...
    www.appliancerepair.net/dishwasher-repair-6.html If the dishwasher is loaded with a lot of food residue, it will need extra rinse cycles .....changes, they will be explained in instructions that come with the new timer. ... If you have an ammeter, the stalled motor will be drawing 10 to 20 amps or more. ... Since the resistance of the heater is very high compared to the resistance of ...
    Pump Repair FAQ - OTP Industrial Solutions
3/17/2016 12:03:39 AM • Hobart... • Answered on Mar 17, 2016
Our dishwasher seems to be stuck on pots. how to cancel this programme?
Does removing the power at the wall do a reset?
3/1/2016 7:52:06 AM • Hobart... • Answered on Mar 01, 2016
Find a clear wiring diagram of the motor conections
Go online and do a google search for the model and see if you can get info on it also call the manufacture to see if they will give you tech support on it also check the machine there is usely a diagram on the machine showing the wiring of unit.
3/3/2015 1:35:35 PM • Hobart... • Answered on Mar 03, 2015
Where do I get a Manual for Hobart Model AM-14 dishwasher
Here you go. https://my.hobartcorp.com/kroger/TechnicalServiceManuals/AM15%20Technical%20Manual.pdf https://my.hobartcorp.com/kroger/TechnicalServiceManuals/AM15%20Technical%20Manual.pdf
2/13/2015 7:52:10 PM • Hobart... • Answered on Feb 13, 2015
0answers
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
12/20/2013 10:18:31 PM • Hobart... • Answered on Dec 20, 2013
Dish machine sticks in rinse cycle
Check the solenoid valve on the rinse piping at the top back of the machine. shut water off and take the coil and the top off of the solenoid, carefully remove the innards (so as not to lose them and to remember how they went together) check for debris inside and clean out. Put it back together and try it. If that doesn't work, you will need to replace the solenoid valve. Cost is around $100 at Grainger for a suitable valve or if you want factory part, it is around $350 from Hobart.
12/20/2013 10:00:04 PM • Hobart... • Answered on Dec 20, 2013
0answers
Hobart AM15-1 Low Temperature Dishwasher. Techs question. I just replaced main board and relay board but now getting a E1 error code, curious if anyone knows what it is?
Question edited for clarity. Error codes should be on the rear label according to the Technical Manual https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf There is no E1 error code for that machine and is is suggested that the display may be faulty. https://www.google.com/search?q=hobart+am15+e1+error+code The only reference to E1 is here, for the AM-16 and an electrical 'type'. https://www.hobart.ca/wp-content/uploads/pdfs/warewash/AM16-BAS-Base-Electric-CF48568.pdf For LXi machines Drain and fill error messages are displayed as E0, E1, E2, E3, E4, E5, E6 or E7. In all cases, the dishwasher will terminate current cycle operations, turn off all heat sources and display the message until the OFF button is pressed. (A power drain will not occur when turned off.) (See Troubleshooting.) If problem persists, contact your local Hobart Service Office Phone Hobart Support. there are no Hobart Techs here, just me as caterer, career long Hobart user and Expert finder of information. Or try JustAnswer dot com. ..
4/16/2024 5:19:38 PM • Hobart... • Answered 2 days ago
Problem on hobart ecomax 602-10
1/4/2024 2:04:53 PM • Hobart... • Answered on Jan 04, 2024
Hobart Dishwasher CL44E showing display PROBE ERROR-WSH PW DR.
To me the Error is telling you Probe Error - Wash - Power - Drain CL & CLe Series Dishwasher Display Codes Below are common codes that display on Hobart CL and Cle Series Dishwashers:
  • Door(s) Open - This displays if one or both doors are open. Close all inspection doors.
  • Clear Conveyor Jam - The code appears if there is a jam. Remove the rack from the machine. Then, press START and rerun the rack.
  • Probe Err - TANK - Check if the lower float assembly in the displayed tank isn't visibly damaged and that the proper amount of water is covering the lower float in the tank.
  • Probe Error - FnlRns - Make sure the supply water valve to the rinse booster is open.
More here and a video https://www.google.com/search?q=Hobart+PROBE+ERROR-WASH+PW+DR https://www.hobart.com.mx/pdf/FichaTec/F-40196.pdf Service Manual https://hvac-talk.com/vbb/attachment.php?s=219f76d9e796c2e5f1c5fef6b79fad9d&attachmentid=830275&d=1639784925 from here https://hvac-talk.com/vbb/threads/2234701-Hobart-Service-Manuals ..
11/14/2023 10:10:01 PM • Hobart... • Answered on Nov 14, 2023
Hobart FT1000 Flight Type Commercial Dishwasher. The final rinse is not showing the temperature number.
Probably the temperature sensor, but do you want to risk $227 on a guess? It is a commercial machine, just call your local service tech. https://www.google.com/search?q=hobart+dishwasher+ft1000+service+manual+pd It is NOT a common fault https://www.google.com/search?q=hobart+dishwasher+ft1000+rinse+temperature+blank ..
8/17/2023 5:44:06 PM • Hobart... • Answered on Aug 17, 2023
2answers
Hobart AM-14 dishwasher is constantly filling with water.
Question edited for clarity and written English. It is a professional machine, you have it serviced professionally by your local Hobart Service Centre and claim the repair against your expenses. The machines are way beyond the capabilities of someone that can just buy parts online. It is either incorrectly wired or the control board or relays are are failing / failed.
8/16/2023 10:14:41 PM • Hobart... • Answered on Aug 16, 2023
2answers
What is wrong with Hobart dish machine says check water level
1.Loss of water pressure due to pump obstruction. Check for any obstruction at the pump intake. 2.Strainers clogged causing inadequate water supply to pump. 3.something may be inhibiting free movement of the low water float; remove any foreign object from around the low water float or its magnet.
4/13/2023 3:03:33 AM • Hobart... • Answered on Apr 13, 2023
Hobart AM14, the float assembly keeps failing. We are on our 4th one. Ruled out heat, electrical and we also replaced the main board. Anyone experienced this before?
It sounds like you're experiencing recurring issues with the float assembly on your Hobart AM14 dishwasher. You've already ruled out potential causes such as heat and electrical issues, and have even replaced the main board to try to resolve the problem. However, you're still encountering failures with the float assembly, which is unusual given that the dishwasher has been in use for 18 years without any prior issues with the float. Without additional information or an on-site inspection, it's difficult to pinpoint the exact cause of the float assembly failures. However, some potential causes could include:
  1. Damage or wear to the float assembly parts: Over time, the float assembly parts may become worn or damaged, which can affect their performance and lead to failures.
  2. Water quality issues: Poor water quality, including high mineral content or excessive amounts of chemicals, can damage the float assembly or cause it to malfunction.
  3. Improper installation: If the float assembly is not installed correctly, it may not function properly and could fail prematurely.
  4. Inconsistent usage: If the dishwasher is not used consistently or is used excessively, this could put strain on the float assembly and cause it to fail more frequently.
It's important to work with a qualified technician who has experience with Hobart AM14 dishwashers to diagnose and resolve the issue. They can inspect the dishwasher, including the float assembly and other components, and identify any potential causes of the failures. From there, they can recommend the appropriate course of action to resolve the problem and prevent future failures.
4/10/2023 7:40:21 PM • Hobart... • Answered on Apr 10, 2023
Hobart Dishwasher Am-14 Commercial Dish Washer Logo
21 questions posted
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
our dishwasher seems stuck pots cancel
  • Dishwashers
