FixYa.com
Acer AOpen AX 5TC  Motherboard
All Products > Acer > Motherboards
Problems with Acer AOpen AX 5TC Motherboard?
Search inside Acer AOpen AX 5TC Motherboard Knowledgebase
Troubleshooting and Support
Solved Problems for Acer AOpen AX 5TC  Motherboard RSS Feed Post a New Problem
ECS PT800CE-A restart problem? (can't turn...
I recently bought ECS PT800CE-A and have installed the motherboard with P4 3.2GHz Prescott (FSB800) CPU. Everything...
1 Solution
wow this is REALLY weird
so i oc my pr 3.2 to 3.32. i think "yes, itwill get hotter, but faster" only the seccond 1 happened. in...
1 Solution
Weird Problemm, Please help.
Here is what happened. Surge Protector got turned off accidently. When i reset the surge protector, everything started...
1 Solution
can't start bios
i can't start my motherboard bios, no beep, not bios output (black screen). The power supply is ok (i tried a new one)....
2 Solutions
BIOS not starting
This is what is happening, when i press the on button, my computer doesn't even budge. So after I unplug it and plug it...
1 Solution
problem with asrock p4i45 mother board...
i have a geforce nvidia 6600 gt... the asrock agi support list reckognizes the card as one that is supported. but the...
1 Solution
Beep sounds and their meaning
Hello, I got this MSI 915P Neo2 motherboard and getting beepsounds at startup. Not the usual one "beep" but...
1 Solution
View All
Tips & Tricks
Post a New Tip
p5s800-vm - Written by josesilvalve
esd precautions - Written by vgopal1952
Specifications
Key Features
Form FactorBaby AT
CompatibilityPC
ChipsetIntel 430TX
Compatible Processors6X86, Cyrix MII, Intel Pentium MMX, AMD K5, AMD K6-2, AMD K6-III
Front Side Bus Speed66 MHz
Technical Features
Storage Controller Type(s)IDE
Memory
Max Supported RAM256 MB
Other Features
Chassis Type1
Dimensions
Depth8.67 in.
Width10.01 in.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
