20 Most Recent Electrolux 134743500 Fridgidaire Washer Motor Control Board Questions & Answers
Our dishwasher drains into the same pipe our sink does, which I think is the case with almost all of them. If the drain pipe is getting clogged, it will be difficult for the dishwasher to drain. I would suggest to try drain cleaner (BE SURE TO FOLLOW DIRECTIONS) and if that does not help I would remove the hose from the drain under the sink and see if the hose itself is getting clogged. Our sink drain also gets to the point that drain cleaner does not work, so I remove the "trap" and clean it out.
Electrolux... | Answered on Jan 03, 2018
Blocked the pump try putting a cleaner through the machine,check pump for obstruction.
Electrolux... | Answered on Jul 26, 2014
no, they have sensors, sensors are likd fuses but interactive, if your dryer wont work, youve got a bad sensor, the exhaust sensor or a thermoister, heater coil heat sensor they are small round devises with wire to them, test a sensor with a continuity meter, while the power if off, sensors have two wires connected to them, if they two wires dont get continuity then they are bad, they are like a fuse but senitive to heat on the dryer, so they will switch off or go bad if you have overheating problems, something clogged in the exhaust or heat coils touching eachother creating extreem heat
Electrolux... | Answered on Jan 01, 2013
Communication problem. Check the wiring between the Main
Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
Electrolux... | Answered on Dec 28, 2012
What is the model number of your unit?
Electrolux... | Answered on Nov 27, 2012
Ok when this happens what it is is water has leaked into the base of the washer and activated the flood switch.
What you need to do is pull the washer out and lean it 45 degress backwards. This will allow the water to drain from the base so you may need a towel for that part.
Once the water is out the flood switch will reset itself and clear this fault. Then see how it goes from there.
But if it happens again then something is leak under there and you need to find the fault and fix it to sort it.
But if you do the above then you should be able to sort it from there.
Electrolux... | Answered 2 days ago
indicates no water flow from taps or the water solenoid is faulty and not opening the valve
Electrolux... | Answered 3 days ago
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Electrolux... | Answered on Aug 09, 2018
do you use powder detergent--if so it could be clay mud from undissolved powder
it it is fluff or other organic material , you may try an organic drain cleaner or possible a caustic solution cleaner if the organic doesn't work
you can check for blocked drain and pump bu lowering then drain hose to floor level
if the tub drains out freely , it will nor be a blockage but a pump problem
Electrolux... | Answered on Aug 08, 2018
To disable the child lock (control panel lock) on the Electrolux EFDE210TIW, press and hold the Dry Time and Wrinkle Release key pad buttons until the indicator light goes off. These are the two buttons to the right of the LCD screen. You will need to hold the buttons for several seconds (usually between 3 and 10 seconds depending on when the dryer was manufactured).
See page 11 in the user manual. The manual is available on the product page: https://www.electroluxappliances.com/Washers-Dryers/Washing-Machines/Dryers/EFDE210TIW/ . The direct link to the English version of the manual is currently http://manuals.electroluxappliances.com/prodinfo_pdf/Webster/136936001en.pdf .
I hope this helps.
Electrolux... | Answered on Jul 25, 2018
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Electrolux 134743500 Fridgidaire Washer Motor Control Board Logo
30 questions posted
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
dishwasher not draining
  • Washing Machines
