20 Most Recent Braun Texstyle-5 510 Iron For 220 Volt not For Use In Usa Questions & Answers
Get your netgear tech issue fixed instantly by calling
<a href="http://rokutechnicalsupportnumber.com/netgear-support/">netgear tech support</a>
Braun Irons | Answered on Nov 18, 2018
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Braun Irons | Answered on Aug 21, 2016
www.braunhousehold.com/global/all-products/home.../steam-irons
Braun Irons | Answered on Jun 11, 2014
You can buy replacement cords and ends at any decent hardware store to make your own cord. However you need to disassemble your iron to make the change. I would only recommend trying this if you are familiar with doing such a task, you wouldn't want to risk a misfire and causing a fire.
Braun Irons | Answered on Aug 27, 2013
I noticed the same problem my friend. The problem with mine was that the wire was having some kind of partial contact at the end inside the iron. The wire was twisted and tangled. I will advice You to
  1. Unscrew the iron from the compartment at the back of the iron,
  2. Then You force up the control of the iron,
  3. You will see 2 screws side by side, unscrew them open to release the lower part of the iron,
  4. Tail the wire to part that it is connected to in the iron,
  5. Then you unscrew the screws that hold the wire and disconnect it from the iron, then you Cut the rough edge of the wire or you can replace the wire completely,
  6. Reverse the process to reassemble the iron back together.
Also another cause might be that the connection to the power socket is loose and disconnects itself while you are ironing. In that case, it is the socket you are to replace.
Some irons are also made that way, that once it gets too hot and is not being controlled, the power will cut off its power supply by itself.
That should do the job for you. Hope this information was helpful.
Braun Irons | Answered on Jan 12, 2011
use the green no scratch pads,they are not so abrasive.
Braun Irons | Answered on Sep 09, 2009
Use these magic words on GOOGLE!
"clean the bottom of an iron youtube"... LOTS of ideas there.
Anthony
Irons | Answered Yesterday
You asked if there was "some way" and here it is... PROVIDING that your remaining parts DO NOT have any loose wires in the parts left over...
Below see this tubular stuff called "heat shrink"... The more it's heated the more it shrinks down in size... Of course there are 'limits' as to how far it will shrink down so picking the right size is very important.
A common hair dryer will aid you in getting a proper 'shrink' and fit.Because it does shrink, do cut it slightly longer than you actually need... it's easy to trim to size later.
Sooo... as the Heat Shrink heats, it molds itself in place and keeps the iron innards in place too (within the handle and under the shrink)!
No worries about electrical shorts or a bad fit ~ unless you pick on a original heat shrink size that is too large thus causing a loose fit? If you find your heat shrink slipping around "AT ALL"... start over with a slightly smaller size.
Also, as it shrinks it gets slightly thicker around "the shrink cylinder outer walls" thus assuring a lasting snug fit! This also provides a slight measure of protection if the iron is dropped on the shrink protected area.
Of course your iron will continue to transfer heat beyond it's "new-formed body" and your flat iron remains quite useful without worries of rubber or particles imparted to your hair!
Here is what the Heat Shrink looks like... Home Depot may have just the size you need... I suspect it may be a $3 fix!
Anthony!
Braun Texstyle-5 510 Iron For 220 Volt not For Use In Usa Logo
1 questions posted
Popular Products
Top Braun Irons Experts
Marvin
Marvin
Are you a Braun Iron Expert? Answer questions, earn points and help others
View Most Popular
Braun Irons
  • Braun Irons
Most Popular Question
braun carestyle iron steam element not
  • Irons
