20 Most Recent
GE Spacemaker GTUP270EMWW Questions & Answers
Washer does not work but dryer does
Sounds like a safety switch is bad like door switch, or a wire has come off or disconnected somewhere. it will have to be taken apart to fix it. If i can help further just give me a shout.
I need to use my GE Dryer now today, but dryer door switch doesn't work.
To do that today, you would need to do the following for older dryers. Turn off the power by pulling the plug From the back remove the console. Remove the top Undo the two screws at the kick strip Carefully remove the front remembering there are wires. Short the wires together and tape them up. Put it all back together. For modern dryers. Some are surface mount and just pull out. Order the part, DON'T leave it like that! ..
2/11/2024 9:22:41 PM •
GE Dryers
Answered
on Feb 11, 2024
Need color codes for ge dryer portable MODEL: DSKP 333EC5WW SERIAL: AL500 100C TYPE: MDU3D TO dryer timer switch Not one no where in dryer nor manual please
I'm sorry to hear that you're having trouble finding the color codes for your GE dryer. Here are the typical color codes for a GE dryer timer switch:
- Black wire: This is typically the power wire and connects to the hot terminal of the timer switch.
- White wire: This is typically the neutral wire and connects to the neutral terminal of the timer switch.
- Blue wire: This is typically the wire that controls the dryer's cycle, such as timed dry or automatic dry.
- Red wire: This wire is typically used for the dryer's buzzer or other signaling device.
However, it's important to note that the color codes may vary depending on the specific model and manufacturer of the timer switch. I would recommend double-checking the wiring diagram for your specific model, which should be located on the back of the dryer or in the owner's manual. If you're still having trouble, it may be best to consult a professional electrician or appliance repair technician.
2/26/2023 2:23:08 PM •
GE Dryers
Answered
on Feb 26, 2023
GE Electric Dryer with Steam - Estimated Time Remaining issue
The estimated time remaining display on your GE Electric Dryer model # GFDS140EDWW is designed to show the remaining drying time in decimal format. The reason for this is that the dryer's algorithm calculates the remaining time based on a number of different factors, such as the load size, type of fabric, and level of dryness selected.
Unfortunately, there is no way to change this setting on the dryer. It is simply the way the display is designed to operate. However, you can use the manual to help you convert the decimal number to minutes. For example, if the display shows 4.1, you can convert this to 41 minutes by multiplying 4.1 by 10.
If you are still having trouble with the display or any other aspect of your dryer's operation, you may want to refer to the user manual or contact GE's customer service for further assistance.
2/26/2023 10:03:00 AM •
GE Dryers
Answered
on Feb 26, 2023
