20 Most Recent Fujitsu ASU9RLF Hybrid Flex Inverter Wall Ductless Indoor Unit Air Questions & Answers
Why does my Fujitsu ductless AC turn on by itself and without me using the remote control?
You would have to figure out what is sending a signal to its receiver. If no signal is being sent then its the signal then it may be the receiver(board) in the indoor unit. Also, other remote controllers for, TV, fans,ps3 or ps4, DVD player, dish ect... have the potential to interfere. I've had/seen a Hunter ceiling fan turn a window unit on 5 mins after you turned on the ceiling fan. Of course the customer was hard to convince. If you want, try removing all remotes to the other side of the house. That's the cheapest thing to try. You can check all wire terminals and grounds to ensure they are tight. Other than that? Work safe!
6/27/2015 12:37:08 AM • Fujitsu ASU9RLF... • Answered on Jun 27, 2015
Lights flashing on the inside unit Futitsu Split System during operation. What do they mean?
Called Flash Codes. First try turning off everything at the breaker for at least 2 hours and preferably overnight. Turn back on and wait 15 minutes for self test to complete. https://www.orionair.co.uk/PDF/fujitsu-trouble-shooting.pdf ..
2/20/2024 4:33:10 AM • Fujitsu Heating... • Answered on Feb 20, 2024
I have a fujitsu airconditioner with red lights flashing 5 times, green light flashing 3 times and economy light flashing continuously
call for service. here is a link to codes copy and paste https://www.alliancecc.com.au/fujitsu-air-conditioning-repairs/
12/22/2023 3:36:53 PM • Fujitsu Heating... • Answered on Dec 22, 2023
I have a fujitsu mini split AOu24RML1 that is not turning on.
I have found that with my Fujitsu Halcyon, it needs to be disconnected from the mains at the breaker for 2 hours to properly reset. Use that time to clean the filters in the wall unit. The clicking you hear is self testing of relays.
8/8/2023 11:49:09 PM • Fujitsu Heating... • Answered on Aug 08, 2023
2answers
Have a Fujitsu Halcyon mini split AC unit leaking on inside.
I have the same unit. The drain line will be outside and is linked to the condensate drain on the outside refrigeration unit. It will be a black plastic or clear polythene tube a half inch in diameter. The bottom is probably blocked. A tech may be able to do it from the inside by blowing compressed Nitrogen gas down the drain. The case obviously has to come off which should be a quick job just 7 screws according to the video help. ..
7/27/2023 6:18:17 PM • Fujitsu Heating... • Answered on Jul 27, 2023
My Fujitsu Inverter was flashing red and green lights. I turned it off at power for 10 minutes. Now it's working but the temperature is not showing. What should I do please?
When I reset mine by turning off at the breaker, I turn it off at least a couple of hours to reset all the control boards. Overnight is even better.
2/8/2023 3:31:03 AM • Fujitsu Heating... • Answered on Feb 08, 2023
2answers
Fujitsu ducted RC aircon (25 yo) error code
The error code 2F00 indicates a problem with the indoor unit's microcomputer. It could be caused by a malfunction in the microcomputer or the communication error between the indoor and outdoor units.
1/15/2023 7:08:23 PM • Fujitsu Heating... • Answered on Jan 15, 2023
Why is my ASU18RLF Fujitsu ductless wall unit have a slow blinking continuous operation light
I think that is Clean Filter error. Lift up the flap and slide it out. Wash it and put it back. The other thing I found with mine is that turning it off at the breaker for 2 hours, fixes most issues.
1/10/2023 2:15:30 AM • Fujitsu Heating... • Answered on Jan 10, 2023
My fujitsu model is blowing cold air
sorry i was answering a question about a car ac/heater .. IDK what a fujitsu is
12/13/2022 4:09:30 PM • Fujitsu Heating... • Answered on Dec 13, 2022
Fujitsu slim duct not heating
12/8/2022 4:15:04 AM • Fujitsu Heating... • Answered on Dec 08, 2022
How change farenheit to celcius, remote control unit model ar-rah2u
Turn off the remote, hold down the temp raise button until you see the F or C appear, hit the temp raise button again to select F or C, turn on the remote.
12/2/2022 7:04:04 PM • Fujitsu Heating... • Answered on Dec 02, 2022
Fujitsu AGU9RLF Only Works in Heat Mode
I told you the fix in your other post.
11/8/2022 6:08:36 AM • Fujitsu Heating... • Answered on Nov 08, 2022
2answers
Fujitsu AGU9RLF Operation Light Blinking
Hi, there might be a filter that needs to be changed or the machine needs service. Please check the troubleshooting section of your product manual to determine the specific meaning of the blinking light and the auto-off that's occurring. If you don't have the manual, then please call Fujitsu and request a copy be emailed to you. If that fails, you might need to take your product into a place like Geeksquad/Bestbuy for servicing. Thank you.
11/8/2022 3:02:04 AM • Fujitsu Heating... • Answered on Nov 08, 2022
I can't turn on Fujitsu aircon
Turn off at the breaker for at least two hours. This will reset all the control boards. I have one of these units.
11/2/2022 9:47:38 PM • Fujitsu Heating... • Answered on Nov 02, 2022
My fujitsu Halcyon indoor unit Operation and timer lights (red and green) flash 4 times and then the timer light (green) flashes three times.
Red 4 Flashes Green 4 Flashes Power Failure Off 3 Flashes Reverse Comms Fail In Use I have one of these units and it has had its fair share of troubles, but great when it is working. My latest issue is the the flap on the indoor unit doesn't open! This generally works for me. Pull out the isolator outside on the wall or disconnect at the breaker. Leave for a couple of hours. Reconnect and wait 15 minutes. If you are connecting via the isolator you will hear relays clicking and solenoids rattling as the unit goes through a Self Test procedure, then try normal operation. Blink Codes and Troubleshooting. https://www.orionair.co.uk/PDF/fujitsu-trouble-shooting.pdf ..
8/10/2022 4:29:51 PM • Fujitsu Heating... • Answered on Aug 10, 2022
Fujitsu ASU9RLF Hybrid Flex Inverter Wall Ductless Indoor Unit Air Logo
1 questions posted
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Heating & Cooling
Most Popular Question
fujitsu ductless ac turn itself without
  • Heating & Cooling
