20 Most Recent
MT&V Dual 7" Headrest Monitors & DVD Player Package 1 (MTV-5277, MTV-5939) Car Video Player Questions & Answers
Just bought a ForJ Dual Headrest with 7
If you still need them, let me know I bought one as well and it had them. I will copy them for you. I can only get the one that has the built in dvd player to get sound the other has video but no sound. Let me know if yours works.
I just bought the dual headrest from walmart and
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
I have the dual headrest
since your unit is not turning on, then it means the unit is having a power problem. The first thing to check is the power board of the player. The power board of the player is defective, that's why its not transmitting or transferring current into the player.
Except the power board is fixed, the unit might not power up again.
If you know about electronics repair, get a meter, open the unit on order to gain access to the power board, use the meter to read the power board to detect for any bad component and make every necessary replacement.
But if you don't know about electronics repairs, then I would advice that you take the unit to a repair man to fix the problem for you.
I hope the above makes sense to you.
Good luck.
For J 9'" roof mount dvd problem
on the unit itself there is a switch for the fm station. look to see what station it is set for and tune your car radio to that station
Iv hade these forj dvd monitors installed but i
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Walmart dual headrest dvd player has no sound on passenger side
