FixYa.com
Apple HP ScanJet 3570c Flatbed Scanner
All Products > Apple > Scanners
Problems with Apple HP ScanJet 3570c Flatbed Scanner?
Search inside Apple HP ScanJet 3570c Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Apple HP ScanJet 3570c Flatbed Scanner RSS Feed Post a New Problem
Mac mini Intel?
Has anyone on this list been successful in getting a Mac mini Intel to work with a HP scanjet 3570c?. If so I would be...
9 Solutions
How to Clean a Scanner?
1 Solution
"A HI SPEED USB device plugged into a...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1 Solution
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
not support window xp
acer scan 620st bit suport window xp
1 Solution
Microtek artix scan 120tf
My microtek negative scans are coming out with a very strong cyan bias, and i consistently get a light cyan strip all...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Apple HP ScanJet 3570c Flatbed Scanner RSS Feed Post a New Problem
HP Scanner 8200 with Mac Mini intel
Anyone been able to make it work with the G4 mac mini or the intel mac mini?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformMac
TypeFlatbed Scanner
InterfaceUSB
Optical Resolution1200 dpi
Max. Resolution (Hardware)1200 x 1200 dpi
Max. Gray Depth8-Bit (256 Gray Levels)
Technical Features
Form FactorDesktop
Input TypeColor
Media
Supported Media TypeSlides · Transparencies · Plain Paper · Bulk Objects (Books, etc.)
Media Loading MethodManual Load
Max. Supported Media Size216 x 297 mm
System Requirements
Operating SystemApple MacOS 9 · Apple MacOS X · Apple MacOS 8
Dimensions
Depth11.82 in.
Height3.35 in.
Width19.7 in.
Weight7.06 lb.
Warranty
Warranty90 Days
Apple Contact Information
Main support number1-800-275-2273
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
