20 Most Recent
Drive Medical "Drive Pacifica Elite Compressor Nebulizer,7.5"W x 4"H x 6.8"D,6/Case" Questions & Answers
How to change bulbs on tga mystere
If there are no visible screw or bolt heads to unscrew, the access to the bulbs is most likely from the back of the light fitting. This means you will probably have to remove the trim panel the bulb holder is fitted into. It isn't a difficult job, (depending on which bulb it is), just time consuming. The panels and fairings are often fitted in a specific order so it turns into a bit of a jigsaw puzzle job.
If you do this yourself have a small container near you to keep all the screws and bolts in and take LOTS of photos as you work your way through the job.
Drive medical scout 3 beeps twice
hi Loria, are you sure its a 3 bleep then 3 bleep then a pause then repeats ?
this is very important, if that is the case it's a controller failure.
3. bleeps and then 2 bleeps
means a issue with the brake ,,, check the scooter not in freewheel when you turn it on ,, if you can push the scooter move the lever otherwise it won't work, now there could be a issue with the connection between the frame and the rear axle where they come apart , try removing and refitting ..
Regards
Rob
How do I access the battery bay on a green power jh500 mobility scooter
hi, its hidden under the black plastic box containing the circuit breaker,
so unlock the back push the seat upwards, Now you see a black plastic box remove four bolts, two at the top and two on the floor of the box,
take care when removing the box you will want to remove one wire , undo the holding screw within the trip switch, isolator switch now put some tape around the exposed wire, pull the box upwards and push to the side of the scooter with one battery wire still connected , now you see the batteries.
Remove the hold plate before doing anything else , make sure you don't touch any battery terminals ..
Regards
Rob
How to fix Drive Spitfire EX 1420 flash code 9
hi, now the connectors they used are very similar if not the same as the Pride go-go series and the trick there is to remove the back axle and refit, try some WD40 on the pins and socket connections, the sockets should be nice and round , the pins should not be discoloured... if the issue still persists , then at worse it a controller internal fault..
Regards
Rob
Mobility pride xl mobility scooter
Hi u don't mention the problemrear axle assembly is very reliable not prone to failure,CHECK YOURE TYRE PRESSURE 30 to 35 .also tighten rear axle NUTS VERY TIGHT loose nuts can cause a thumping noise........cheers
