FixYa.com
ASUS TM-230 Micro ATX Mini-Tower Case
All Products > ASUS > PC Cases
Problems with ASUS TM-230 Micro ATX Mini-Tower Case?
Search inside ASUS TM-230 Micro ATX Mini-Tower Case Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS TM-230 Micro ATX Mini-Tower Case RSS Feed Post a New Problem
chassis help
i bought asus chasis ta-8, and a motherboard asus p5pe-vm. the problem i am havin is that iam unable to sort out the...
1 Solution
Fan noise
I find that the side mounted fan is noisy in my new PC with 8870LK case.
1 Solution
Apple Mac 9600/350 problems
Hi, Im having trouble with my 9600/350. It used to run fine, but Ive since upgraded a few things to put it to work in...
1 Solution
continuation to 'help no power' question?
further to the reply, can you please inform me to whether the motherboard could be ruined from the short? if I put...
1 Solution
loader
The front knuckle is leaking oil. We want to know how to pull it down and repair it.
1 Solution
Gigabyte hard drive rails
Now it may not seem like a big thing but i've found getting hard drive rails for the Gigabyte 3D Aurora to be near...
1 Solution
manual for hp 4300 notebook
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
Cabinet Form FactorMini-Tower
Motherboard Form FactorMicro ATX
Power Provided300 Watt.
Technical Features
Power TypePower Supply
Expansion Bays2 x 3.5" (External Access) · 2 x 5.25" (External Access) · 3 x 3.5" (Internal Access)
Front Panel PortsAudio in · Audio out · USB 1.1 x 2
System Cooling Method1 x 80 mm fan · 1 x 90 mm fan
Total Fans Amount2
Other Features
Exterior ColorWhite
Dimensions
Depth15.2 in.
Height14 in.
Width6.7 in.
Weight13 lb.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
