FixYa.com
ASUS TA-230 ATX Mid-Tower Case
All Products > ASUS > PC Cases
Problems with ASUS TA-230 ATX Mid-Tower Case?
Search inside ASUS TA-230 ATX Mid-Tower Case Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS TA-230 ATX Mid-Tower Case RSS Feed Post a New Problem
Fan noise
I find that the side mounted fan is noisy in my new PC with 8870LK case.
1 Solution
Apple Mac 9600/350 problems
Hi, Im having trouble with my 9600/350. It used to run fine, but Ive since upgraded a few things to put it to work in...
1 Solution
help no power
i installed very thing to my new alien gaming case (atx case) plug in after checking things over and over again but no...
1 Solution
continuation to 'help no power' question?
further to the reply, can you please inform me to whether the motherboard could be ruined from the short? if I put...
1 Solution
Computer powers off and must be unplugged...
I have a Gigabyte motherboard in a CAC-T05-UWI case. Occassionally the computer will power off and refuse to power on...
1 Solution
my 500W powered aspire alienware case
I am having problems getting my panel leds wired up. My ECS MB doesn't list the configuration from my case and the plugs...
1 Solution
extra red color in moniter graphics
moniter is denoted everything in red color and i can not see the original picture.
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
Cabinet Form FactorMid-Tower
Motherboard Form FactorATX · Micro ATX
Power Provided300 Watt.
Technical Features
Power TypePower Supply
Expansion Bays4 x 5.25" (External Access) · 4 x 3.5" (Internal Access) · 2 x 3.5" (External Access)
Front Panel PortsAudio in · Audio out · USB 1.1 x 2
System Cooling Method1 x 80 mm fan · 1 x 90 mm fan
Total Fans Amount2
Other Features
Exterior ColorWhite
Dimensions
Depth17.3 in.
Height16.7 in.
Width7.4 in.
Weight16.2 lb.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
