FixYa.com
ASUS Intel 850 Chipset P4T Motherboard
All Products > ASUS > Motherboards
Problems with ASUS Intel 850 Chipset P4T Motherboard?
Troubleshooting and Support
Solved Problems for ASUS Intel 850 Chipset P4T Motherboard RSS Feed Post a New Problem
PC don´t boot after upgrading BIOS
I was upgrading the BIOS using the Asus EZFlash Utility but it failed to confirm the change, after that the aplication...
1 Solution
Asus P4T newbe question about Intel...
Hi Do i need to install the Intel 850 INF chipset drivers and the Intel ulta ATA storage drivers when using...
8 Solutions
ECS PT800CE-A restart problem? (can't turn...
I recently bought ECS PT800CE-A and have installed the motherboard with P4 3.2GHz Prescott (FSB800) CPU. Everything...
1 Solution
cpu fan is turning , but the BIOS display...
when the motherboard starts up , there is always warning sound, and ask to shutdown or not. actually the cpu fan is...
4 Solutions
MotherBoard Help
Hi, i just got done finishing up with my mother board everything seems to be ok. I just noticed that my...
1 Solution
Troubleshooting with a multimeter
how to: Troubleshooting with a multimeter
2 Solutions
Weird Problemm, Please help.
Here is what happened. Surge Protector got turned off accidently. When i reset the surge protector, everything started...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetIntel 850
Compatible ProcessorsIntel Pentium 4
Front Side Bus Speed400 MHz
Processor
Max supported CPUs qty1
Memory
Max Supported RAM2 GB
Memory TypeRDRAM (RAMBUS)
Other Features
Chassis Type1
Dimensions
Depth9.61 in.
Width12.02 in.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
