20 Most Recent
ASUS (P4BGV-MX) Motherboard Questions & Answers
Sound driver realtek
have you tried to go to asus website and look up the motherboard and see if there are any updates to the drivers
No sound from my speakers set
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4BGV-MX&p=1&s=15Here is no drivers for windows 7, because the mainboard does not support this system.Is the sound or audio driver installed, for the windows system ???If not, you can download the driver, by selecting your window system.Your speakers must be connected to the green outlet, and make sure the speakers is on, and make sure the volumen is not turned down low, or muted.Good luck
PC not booting
Are all your LED cables in the right place? Is the motherboard grounded properly, make sure there are no screw holes on the motherboard. Also some of the newer motherboards need power plugged in in 2 places on the motherboard.
I82801@P4BGV-MX audio ctrler invisible in devmgmt.msc
open device manager and i m sure that it will be given under system devices because all the devices that does not come under
unidentified devices are in the system devices list check it there or instead use some software like driver detective to find all the devices connected to the computer and get their device drivers
Bootup
a bad power supply or a hairline crack in the mobo
I want video drivers for tis model........
You can download drivers here.
You will need to select your OS if it is not XP.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
Asus Motherboad P4B screen
I think the problem is on your motherboard, because in this time windows is not loaded yet. So, check out your motherboad, or take it to service center (if you have no experience in hardware fixing)
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
