ASUS PU-DLS Motherboard
Problems with ASUS PU-DLS Motherboard?
Keep your PC up-to-date. Get a Free Scan for ASUS's latest driver updates.
Troubleshooting and Support
Solved Problems for ASUS PU-DLS Motherboard RSS Feed Post a New Problem
shuttle pc motherboards
Hi I am trying to upgrade my shuttle pc, but I am finding it hard to get components that fit into a shuttel pc. E.G....
1 Solution
On the MSI 7145 v2 motherboard, some...
ON jA1 I was able to get the hdd yellow led and the blue power led operational, but I can't seem to get the power...
1 Solution
format a corrupt system without 98...
Is it possible to format a c:of win98 in a corrupt system without bootable?if yes then how?
1 Solution
Removing hard drive
How do I remove and replace a hard drive on my laptop.
1 Solution
check engine light 2001 ford taurus
the first reading i got was mass airflow sensor bad replaced with new one problem hasnt been removed code reads not...
1 Solution
sobre micro y placa madre
deseo saber ademas de el soket 7 si le sirvbe a la aptiba de ibam potro tipo de micro conotro soket o se le puede adptar...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Form FactorExtended ATX
CompatibilityPC
ChipsetIntel E7501
Compatible ProcessorsIntel Xeon
Front Side Bus Speed533 MHz
Processor
Max supported CPUs qty2
Memory
Max Supported RAM12 GB
Audio / Video
Installed Video Memory8 MB
Video InterfacePCI
Communication
Networking TypeNetwork Adapter
Other Features
Chassis Type1
Dimensions
Depth13 in.
Width12.02 in.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
Loading problems.
Top Experts
Ask Me
map9966 Guru
58 solutions
Ask Me
antiochpc Guru
2 solutions
Ask Me
mrsno Guru
2 solutions
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
