FixYa.com
ASUS E7501 533fsb  Motherboard
All Products > ASUS > Motherboards
Problems with ASUS E7501 533fsb Motherboard?
Search inside ASUS E7501 533fsb Motherboard Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS E7501 533fsb  Motherboard RSS Feed Post a New Problem
BIOS intermittently loses CDROM
I have an OEM PC with a BIOS ID of 03/15/2005-601-686A-6A6LIB09C-00. If the PC reboots in XP, it intermittently loses...
1 Solution
usb driver motherboard transcend win 98
ts-avd3 i need to download driver for usb driver motherboard transcend win 98
1 Solution
Motherboard Jumper spots
I installed a working motherboard. Now I can not find the correct jumpers to put these pins on it like Power Switch, HDD...
1 Solution
regarding compatible memory
i have a board ecs k7ama i wanna know its specification and the compatibility of memory aside from 266 thanks
1 Solution
Mainboard OC Failure
Hello. I have a problem with overclocking. My mainboard is MSI 945P Platinum. When I try to overclock it to more than...
1 Solution
laptop problems
when i use nero7 in the middle of me burnind a disk my computer just shuts down with out the disk burning is complete. I...
1 Solution
On the MSI 7145 v2 motherboard, some...
ON jA1 I was able to get the hdd yellow led and the blue power led operational, but I can't seem to get the power...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetIntel E7501
Compatible ProcessorsIntel Xeon
Front Side Bus Speed533 MHz
Technical Features
Expansion SlotsPCI x 2 · PCI-X 64 Bit (100/66 MHz) x 4
Integrated Input/Output PortsUSB 1.1 x 2 · Serial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · Floppy Port x 1 · RJ45 Lan Port x 2
Storage Controller Type(s)DMA/ATA-100 (Ultra) x 2
South Bridge ChipIntel ICH3-S
Processor
Max supported CPUs qty2
Memory
Max Supported RAM12 GB
Memory TypeDDR SDRAM
Number of Memory Slots6 x 184 Pin DIMMs
Audio / Video
Video InterfacePCI
Integrated Graphic CardIntegrated Graphic Card
Video Out Ports15 Pin D-Sub VGA port x 1
Communication
Networking TypeNetwork Adapter
Other Features
Package Qty1
Chassis TypeDesktop
Dimensions
Depth12 in.
Width13 in.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
