FixYa.com
ASUS Intel 440BX Chipset MEB-VM Motherboard
All Products > ASUS > Motherboards
Problems with ASUS Intel 440BX Chipset MEB-VM Motherboard?
Troubleshooting and Support
Solved Problems for ASUS Intel 440BX Chipset MEB-VM Motherboard RSS Feed Post a New Problem
Motherboard/BIOS Upgrade for HP Pavilion...
Hi, I was hoping someone could tell me exactly which motherboard is used in the Pavilion 6736 KR? HP specs only show...
3 Solutions
help wanted.. really weird..
help! when i plug the power cord to the power supply, the cpu automatically run itself, but the screen is just blank...
1 Solution
hard drive recognized as slave drive
i have a fic va 503+ motherboard the primary hard drive is a western digital 60 gb its recognized as a slave drive even...
1 Solution
Serial port connector for Asus Motherboard
On an Asus motherboard I am considering, there is a 10 pin connector to which you can attach a 9 pin RS-232 port that...
1 Solution
No boot...no nothing...I am screwed
I am having a huge problem... I took the heatsink off of my CPU in order to replace it and while it was off, I was on...
1 Solution
my dell pentium 2 with windows XP...
hi guys my dell computer with a windows XP professional keeps on re-stating it self and it does so even when am at the...
1 Solution
ethernet adapter problem
9 months ago I bought the asus motherboard and 3 things don't work... .1. the Ethernet adapter dosn't work (the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorMicro ATX
CompatibilityPC
ChipsetIntel 440BX
Compatible ProcessorsIntel Celeron
Front Side Bus Speed100 MHz
Technical Features
Expansion SlotsAGP x4 x 1 · PCI x 2 · ISA x 1
Integrated Input/Output PortsSerial Port x 2 · USB 1.1 x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · Game/MIDI Connector x 1 · Floppy Port x 1 · Infrared Port Header x 1
Storage Controller Type(s)DMA/ATA-33 (Ultra) x 2
Processor
Max supported CPUs qty1
Socket TypeSocket 370
Memory
Max Supported RAM512 MB
Memory TypeSDRAM
Number of Memory Slots2 x 168 Pin SDRAM DIMMs
Audio / Video
Audio OutputLine Out
Installed Video Memory8 MB
Video InterfaceAGP 2x
Audio InputMicrophone Jack · 1 x Line In
Video Out Ports15 Pin D-Sub VGA port x 1
Integrated AudioAC'97 Audio Codec
Other Features
Chassis Type1
Other FeaturesDual Channel Memory Architecture
Fans1 x 3-pin fan headers
Dimensions
Depth9.61 in.
Width9.61 in.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
