20 Most Recent
Ingersoll Rand 15 Horsepower Rotary Screw Air Compressor System, , Up6-15 Questions & Answers
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds)
Search Results
www.ingersollrandproducts.com/...
Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Oil seperator
Get the model and serial number located to the right side of the fuel tank 1/2 way up on the radiator and call someone who deals in Ingersoll rand (now Doosan). If you remove the old one you can read the numbers off the bottom of it.
Oil seperator
Some oil is common, make sure you haven't over filled the crankcase as this causes too much pressure. The crankcase feeds back to the air filter via a reed valve. If that valve is stuck open the oil will be excessive
I have a 50KW genset
There should be a tag on the radiator of who the radiator manufacturer is and they should be able to supply you with a replacement or try contacting an Ingersoll Rand distributor for help http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31039.
I have a G-235 generator
Your generator should be running @ 1800 rpm if its diesel . I have a 40 kw diesel generator and it starts up and runs a full 1800 rpm with no load . Thats how there designed because they have a 4 pole alternator. Hope this helps.
Generator fired up instantly.
Hello. Siphon out that fuel and start with fresh, new fuel. Then get a can of starter fluid and an assistant. Spray some of the starter fluid into the air intake and start it up. have the assistant continue to spray a bit of starter fluid into the air intake until it takes off on it's own. Joe
