FixYa.com
ASUS K8V-SE Deluxe Motherboard
All Products > ASUS > Motherboards
Problems with ASUS K8V-SE Deluxe Motherboard?
Troubleshooting and Support
Solved Problems for ASUS K8V-SE Deluxe Motherboard RSS Feed Post a New Problem
new motherboard
Ok l think the k8v se deluxe board is shot is there a board out there that i can get that the processor will swap over...
3 Solutions
Speakers humming bad
What can cause the speaker output to hum really bad on this????
1 Solution
case swap
I just installed this motherboard into a new case. The corner where the secondary ide slot is gets pretty warm is that...
1 Solution
cpu test
is it better to put them on the tops or the bottoms??
1 Solution
system failed cpu test
getting a system failed cpu test only when installed in a case will work just fine if out of case
1 Solution
Problem w/ SATA HD on ASUS K8V SE Deluxe...
Im building a new computer and im having a problem with my two new hard drives (1 is a Samsung 120GB SATA Hard Drive,...
4 Solutions
problems with Promise 20378 RAID mode and...
I have an Asus K8V SE deluxe and was wondering if the following behavior is by design. If I enable both the SATA on...
2 Solutions
View All
Tips & Tricks
Post a New Tip
USB Problems - Written by bachari
esd precautions - Written by vgopal1952
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetVIA K8T800
Compatible ProcessorsAMD Athlon 64
Front Side Bus Speed800 MHz
Technical Features
Expansion SlotsAGP x8 x 1 · PCI x 5
Integrated Input/Output PortsSerial Port x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · RJ45 Lan Port x 1 · FireWire (IEEE1394a) x 2 · Game/MIDI Connector x 1 · USB 2.0 x 8
Storage Controller Type(s)DMA/ATA-133 (Ultra) x 3, Serial ATA x 4
South Bridge ChipVIA VT8237
RAID SupportRAID 0 · RAID 1 · RAID 0+1
Processor
Max supported CPUs qty1
Socket TypeSocket 754
Memory
Max Supported RAM3 GB
Memory TypeDDR SDRAM
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Number of Memory Slots3 x 184 Pin DIMMs
Audio / Video
Audio OutputLine Out · SPDIF out
Video InterfaceAGP 8x
Audio Input1 x Line In
Integrated AudioADI 1980
Communication
Networking TypeEthernet, Gigabit Ethernet, Fast Ethernet
Other Features
Package Qty1
Chassis TypeDesktop
Dimensions
Depth9.6 in.
Width12 in.
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
