20 Most Recent
Altec Lansing ACS 56 Computer Speakers Questions & Answers
I need service manual
Google ot best bet most of the time justwrite the model no and brand and put the letters pdf at tthe end
Someone gave this model acs54
You could try to get it at this website:
http://www.alteclansing.com
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
How do I open the
You probably can't. Not without damaging the speaker. Altec is not a major brand, its all probably bonded and glued together by way of easy manufacture.
I plugged my speakers into
Verify that the speakers are plugged into the correct color coded plug in back.
Verify that the speakers are plugged into a power source
Verify that the speakers are on
Verify that the speakers are turned up on the actual speakers
Verify that your sound is not muted in windows (Control Panel > Hardware and Sound (vista) or just Sounds in XP > Adjust system volume. You can also try opening Windows Media Player and unmuting/turning volume up there.
Try several files, mp3s, videos. make sure its working.
If you still have no sound try updating the drivers for your sound card, you can figure out what type of sound card you have from the control panel, system, device manager, sound. then just go to that companys website and search for your card to download the latest.
If you do all of this you should have working sound... if you still dont then that would indicate the speakers or a cable is defective, you may want to do some trial and error with known good cables/speakers.
Altec lansing acs54 installation
Hello there!! jlee432
The 4.1 speakers you has, and output sound , depend on the sound card you has on your laptop. If you has inside the laptop a sound card 5.1 you whould not have problems get it sound, BUT you have to set on multimedia and sound for 4.1 according.
you only have one output sound on your laptop, so you have to use 2 speakers or buy a splitter and get 2 speakers sound.
you also, can buy a pcmcia sound card, 5.1 from creative labs, to solve this. but check if your speakers of course sound of.
good luck
New computer, old speakers
Very easy just plug the jack at the back of the computer. In the sound card it is color coded. So plug it in the green one.
