20 Most Recent Canon BubbleJet i320 Printer Questions & Answers
check ink levels and if wireless check connected , has it a cd for setup
Canon BubbleJet... | Answered on Sep 20, 2017
Open the cover and look for a strip of plastic that the cartridges move along. BE VERY CAREFUL NOT TO DISCONNECT THIS PIECE. If you can access it use a damp cloth to wipe any ink/dirt from this - DO NOT use chemicals as there are markings on this strip that are used for positioning. The slamming is caused because the printer cannot read the cartridge position.
Canon BubbleJet... | Answered on Apr 15, 2013
Hi, the problem is the print head, it is dirty. Usually this happens when you use "compatible" ink and it cloggs the head. Othertimes can be from dust getting into the printer on dirty paper. You can buy Cleaning Ink cartiridges online which can help remove the dirt. If you google search for: "i320 cleaning " you will see these for sale. You can also trty cleaning the Heads yourself with warm water and a lint free cloth but this can be fiddly and messy.
Canon BubbleJet... | Answered on Oct 30, 2011
In this printer the head is separate from the cartridges and in a single block. The cartridges go in it and the block goes in the print head carrier. Because of that in time the connections between the head block and the carrier gets dirty and the heads can no longer communicate and be recognized by the mainboard of the printer.
To clean those contacts remove the cartridges and lift the grey lever that holds the print head block secure in the carrier - the lever goes up from the front and to the rear. Now just tilt the bloc forward and lift it up. With a rough piece of paper wash and clean the contacts at the rear of the block; then take a q-tip and clean the contact pins from the carrier. At the end put all back together and try again.
If the heads are still not recognized then the dirt has corroded the contacts. This is unfixable and because there are no replacement parts it means that the printer is dead. Time for a new one.
Canon BubbleJet... | Answered on Aug 09, 2011
The drivers that you need for devices such as plug-in cards, printers, webcams, scanners, etc. Are usually contained on a driver CD that was shipped from the manufacturer with the device. If you do not have this CD, you will have to visit the manufacturer's website to download the drivers that you need. Go to http://www.canon.com/support
Once you get to the website, look in the support or downloads section of the site for the model number of your device.and select the drivers you need for download.
In the event that you cannot locate the driver(s), look for a "contact us" link on the website support or home page. This link will provide you with contact information (phone or E-mail) and allow you communicate your problem to them.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Canon BubbleJet... | Answered on Jun 26, 2011
did you try printing using Microsoft office or from other application? i feel your black ink is finish.
Canon BubbleJet... | Answered on Jun 20, 2011
Does it have a cancel button? If so press it, check the ink and paper and stuff, good luck.
Canon BubbleJet... | Answered on May 22, 2011
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Canon BubbleJet... | Answered on May 10, 2011
When lights flash on the printer this means that there is an error and the printer is not ready to print.
You can use the BJ Monitor application to see what the error is.
To open the BJ Monitor application, click the fixitguynz_1.gif icon in the System Tray
Regards,
Andy
Canon BubbleJet... | Answered on May 02, 2011
It appears that the print head is not seated correctly. I will advise you to take it out and re-seat it correctly.
Canon BubbleJet... | Answered on Apr 04, 2011
How do you know its working? Did you check your ink levels? Try checking it, your ink may have finished. Also try printing a test page. If it still doesn't work, try reinstalling your print cartridges.
-JS
Canon BubbleJet... | Answered on Mar 09, 2011
Normal 0
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Canon BubbleJet... | Answered on Sep 26, 2010
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Canon BubbleJet... | Answered on Sep 18, 2010
tigallant,
It would certainly not be a bad thing to do a manual cleaning. If this problem just started when the cartridges were replaced there are several possiblilities.
Now days inkjet cartridges are being refilled and sometimes sold as new units. My experience has been that sometimes they work and sometimes they don't. If manually cleaning the cartridges does not work I would return them to the store you purchased them from and exchange them for another set. I have never had a store turn me down on this.
If the next units do not work either I would go to Cannon's website at http://www.usa.canon.com/cusa/support where you can input your model number and download a new version of the driver for your printer. This may require a restart to install.
This should solve your problem.
Thanks for using FixYa and for the generous rating.
hardrocko
Canon BubbleJet... | Answered on Sep 12, 2010
First check for foreign objects in the printer cartridge area or a loose print head.
Then there are two possibilities if it was a Printhead error. You can replace the printhead. Order one from Canon support: 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. Say Order Parts to be connected to the Parts Desk. Be sure to have your model number (i320) or part number (QY6-0044-000) ready for the sales person. This is a non-returnable item. The other option is that the entire printer needs repair (professional service).
You can't tell which issue you have until you try a new printhead.
I wish that I could be of more help.
(printhead alignment and cleaning are much easier to check.)
Canon BubbleJet... | Answered on Aug 15, 2010
put the cartridge though its cleaning cycle, as jets do dry up ,
Canon BubbleJet... | Answered on Jul 07, 2010
Canon BubbleJet i320 Printer Logo
55 questions posted
Clive
Clive
old marine
old marine
View Most Popular
BubbleJet Canon
  • BubbleJet Canon
Most Popular Question
every time try
  • Office Equipment & Supplies
