Canon LBP 3260 Laser Printer
Problems with Canon LBP 3260 Laser Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Canon LBP 3260 Laser Printer RSS Feed
Click here to get instant support from our best Experts!
View More Results for Canon LBP 3260 Laser Printer
Questions and Unsolved Support Problems
Unsolved Problems for Canon LBP 3260 Laser Printer RSS Feed
Answer
Can anyone help to clear the 120k Maintenance counter from the display on a Brother HL3260. I can... (More)
Find a Manual
Canon LBP 3260 Laser Printer Manuals & Guides
Tips & Tricks
(Post a New Tip)
Black lines through scanned & faxed documents
Are you getting black lines through your scanned or faxed pictures and documents? The problem is usually ink or correction fluid on the scanner glass.... written by buddymc
Can't print: Documents Stuck in Queue
When a printer document does not print and all cables are securely connected,usually this due to the print spooler. This is a service that is... written by IT Tech Rep
HP Printer not printing all Models.
Any HP printer has a printer head if you run the ink cartridge out of ink you can burn out the printer head Also Trying to refill these print... written by avid101
How to change xerox phaser 7300, 2135 engine control board
Hey guys I found a video that shows how to remove and change the 7300 engine control board and also the 2135. You can do it yourself!!... written by elmojado
how to clear printer not spooling error on windows xp system.
this error comes in many terms on the monitor screen as such " printer spooling error" " printer not spooling" " printer... written by charlymonty
HP All-In-One can send but cannot receive fax or can receive but cannot...
One of the most common problems with HP All-in-One Printers is that they can send out fax but cannot receive or they can receive fax but cannot send.... written by virtualhost
Setting up (HP Jetdirect print server) Printers on a network
To install the HP printers with a built-in Jetdirect print server as a network printer you need to do the following - 1. Configure the HP's IP address... written by Geekman
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when... written by SpideRaY
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for LBP 3260 Laser Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Rate and Review the Canon LBP 3260 Laser Printer
Write a review:
Rate this product:
Would you recommend the LBP 3260 Laser Printer to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Canon LBP 3260 Laser Printer
Key Features
Platform
PC
Type
Workgroup
Technology (Detailed)
Laser
Black Print Speed
32 ppm
Output Type
Monochrome Printer
Max Resolution (BW)
600 x 600 dpi
Technical Features
Duplex Printout
Optional
Language Simulation
PCL 5E · PCL 6
Media
Media Type
Transparencies · Plain Paper · Envelopes
Max Media Size
A3 (297 x 420 mm)
Total Media Capacity
1100 Sheets
Warranty
Warranty
1 Year
Dimensions
Depth
22.22 in.
Height
21.28 in.
Width
22.3 in.
Weight
110.25 lb.
Canon Contact Information
Main support number1 800 828-4040
Describe your problem:
Top Printers Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
