20 Most Recent
Canon BJC 4400 InkJet Printer Questions & Answers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
Light Orange - 2 beeps: Remove any paper jammed
Light Orange - 3 beeps: Remove any paper jammed
Light Orange - 4 beeps: Add Ink
Light Orange - 5 beeps: Re-install cartridge or replace it
Light Orange - 6 beeps: Re-install cartridge or replace it
Light Orange - 7 beeps: Re-install cartridge or replace it
Light Orange - 8 beeps: Waste is almost full
Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Canon BJC-4400
I got it resolved. I found a website where I could download updated software.
Hooking printer laptop
connect the printer cable to the usb port sir, and plug the power cable to the printer.. then turn it on.. thats all...
