20 Most Recent Canon i475 InkJet Printer Questions & Answers
if its been sat for a year it will need new cartridges. ink drys out over time when empty it drys to the head as there is nothing to keep it wet.
Canon i475... | Answered on May 15, 2017
This is basically ink tank error.
You have to reset ink tank
1.Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Thank You
Canon i475... | Answered on Feb 09, 2011
just follow this step
1.0 click start
2.0 printer and faxe
3.0 right click your printer
4.0 click offline
5.0 got yah!
Thanks!
RF Mercado
Canon i475... | Answered on Jun 26, 2010
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Canon i475... | Answered on Mar 15, 2010
Dear,
You must be change cartridge head then solve your problem, Buy new one head.
Canon i475... | Answered on Dec 12, 2009
Wat difficulties you have when u try to install the software.
Canon i475... | Answered on Jul 24, 2009
hi
well there can be many issues related to the problem related to your problem
1>drivers not working
2>pad need to be changed
etc
you can contact our senior expert on--------------
http://tinyurl.com/ng46w9
Canon i475... | Answered on Jun 22, 2009
If it says passage blocked then there is a piece of paper stuck in it somewhere. Look closely for a paper jam.
Canon i475... | Answered on May 26, 2009
uninstal the driver and reinstal it , recalibrate the printer.
Canon i475... | Answered on Jan 23, 2009
have the same problem and nobody have the solution.
Japyval
Canon i475... | Answered on Oct 23, 2008
Canon i475 InkJet Printer Logo
35 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon i475d showing error
  • Office Equipment & Supplies
