20 Most Recent Canon S400 InkJet Printer Questions & Answers
is your printer connected with a serial cable, if so, you may have to install the printer and software again, but if you are connected via usb and this is the given error then there is a connection fault as, you may already know that LPT1 is not a usb connection but serial cable.
Canon S400... | Answered on Jan 21, 2012
under printer driver properties on your computer,under print preferences, check the print quality settings. i.e if the quality is set to draft change to high.
Canon S400... | Answered on Aug 23, 2011
Hello thhe fix for this is
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Canon S400... | Answered on Jan 29, 2011
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Canon S400... | Answered on Oct 25, 2010
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Canon S400... | Answered on Apr 25, 2010
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
With the printer on, open the lids and wait for the ink tanks to center, as when you put new ink tanks in. Unplug printer. With a flashlight, good tweezers, and small hands (or enlist the help of someone who has them, or get loooong tweezers), reach in over the right where the ink tanks usually rest. Carefully remove the two pads which are held in only by a formed rubber foot. These two pads are porous but stiff plastic. Rinse them in water (in a bowl and carefully so that you don't lose them down the sink!) until the water stays clean. Thoroughly dry them by gently squeezing between paper towels. Swab area that they were sitting in with cotton swabs if you see any pools of loose ink. Replace pads. Reset printer's computer
Reset ip2000 / 3000
1. Turn off printer
8. Your printer should respond as normal..
Canon S400... | Answered on Mar 31, 2010
Hi there ok try
1. Turn off printer
Canon S400... | Answered on Feb 13, 2010
1. Turn off printer
All the best Pineworks
1. Turn off printer
Hi You can Try
Error Code 5100 This happens lots in caon
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Canon S400... | Answered on Jan 28, 2010
There is always a protective film on the prit nozzles. Remove it. Also from the Printer Manager clean the print head.
Canon S400... | Answered on Nov 08, 2009
pls try to reinstall printer
Canon S400... | Answered on Oct 29, 2009
Tip
Perform Paper Feeding Self Test
Applicable models:
S300 and above,i450 and above,Pixma iP2000 and above,IX4000/5000,Pro9000,9500
Procedure (In stand by condition)
  • Set A4 paper in auto sheet feeder
  • Hold down RESUME button until LED indicator blink twice
  • Release RESUME button
Source: Inkjet Forum
on Oct 10, 2009 | Canon S400 InkJet Printer
Canon S400 InkJet Printer Logo
44 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
S Canon
  • S Canon
Most Popular Question
paper in printer not being fed
  • Office Equipment & Supplies
