paper was fed in from the side and there is a jam now. When I take the toner cart. out, you cannot...
(More)
paper was fed in from the side and there is a jam now. When I take the toner cart. out, you cannot see the paper. Yet, from the other side I can see where my staff tried to pull it out, and just tags are left. It could even be accordianed(?) in only and inch of space?
thanks.
black smudges on paper plus faint double images of print copy on paper on canon printer image class...
(More)
black smudges on paper plus faint double images of print copy on paper on canon printer image class D680
my copies are smuged with black and an image of the copied material in the background of the copy. I...
(More)
my copies are smuged with black and an image of the copied material in the background of the copy. I have cleaned everything including 4x having the roller clean itself. Any thoughts?
Suddenly I have an error message "The platen is open," but evrything is closed including...
(More)
Suddenly I have an error message "The platen is open," but evrything is closed including the platen. I tried to turn off the copier and replace the toner, etc., but nothing seems to work.
We were making two sided copies using the auxiliary paper tray (not the auto docuument feeder). We...
(More)
We were making two sided copies using the auxiliary paper tray (not the auto docuument feeder). We think that it gets hot (fuser?) and then the paper jams where it exits the copier onto the tray. Half is in copier and half out. We cannot access this area. How can we take apart to remove this jam? Any diagrams of this area of copier that would help? This is the third time this has happened when making multiple two sided copies. Copier is fine otherwise
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks...
written by fastrepairguide
Applicable models: S300 and above,i450 and above,Pixma iP2000 and above,IX4000/5000,Pro9000,9500 Procedure (In stand by condition)
Set A4 paper in...
written by xanda
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just...
written by Viper-xp
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center. However, this is...
written by worldvet
This works with most canon printers and can fix these problem 1.) Printer Not responding 2.) WASTE INK COUNTER FULL 3.) Waste resivour full 4.) Other...
written by DARKLORD1
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master...
by Soulvisitor
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with...
by wikihow
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on...
by wikihow
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check.
Steps:
1. Go into Microsoft Word.
2. Create four small...
by wikihow
'Resetting' your Lexmark x3350 All-in-One
So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My...
by TTonyTigger
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Celebrating 14 Years Of Outstanding Printer Repair And Designjet Plotter Repair. Serving Nationwide,Serving your Area, Get Local, On Site Certified Printer Today......
Elite printer Services, Inc. is a full service HP & L... Read More
Elite printer Services, Inc. is a full service HP & Lexmark repair facility. We repair, service, sell HP & Lexmark printers and most name brand scanners. We perform maintenance and repair HP Plotters as well. We sell New Compatible and OEM toner for all printer devices. Email us for a quote or serv
Accram is now one of the largest nation wide mai... Read More
Accram is now one of the largest nation wide maintenance service providers in the US. Headquartered in Phoenix Arizona, Accram has earned a reputation for unsurpassed customer service. Our business motto is: Uptime, All the Time. At Accram, we live and breathe our business motto
