20 Most Recent
Canon imageCLASS D320 All-In-One Laser Printer Questions & Answers
Download
Mine will download( to d/l folder) & install but does not show up on printer list. help!!
Can install cartridge message mean current cartridge needs to be replaced?
This error means that the printer is not able to connect properly to the cartridge's chip!
Inspect the cartridge, every cartridge have a chip,
Clean it with isopropyl alcohol, or normal alcohol (But it needs more time to dry)
Clean the printer contacts that connects to the chip on the cartridge with isopropyl alcohol.
Reinsert the cartridge into the printer
and see if something change.
Is the problem still remain, probably the cartridge have a bad quality chip.
Black streaks
This is caused by a rotating part that is contaminated, most likely the drum that transfers the toner to paper.
A new drum or drum cartridge is probably needed.
There is a very remote chance that the high voltage that charges the drum is being modulated but I have seen this once in decades of service.
Canon h12256
most likely the power supply is blown next time get a power surge...try replacing the power supply or take it to a printer fix shop
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
