20 Most Recent
Canon CanoScan D1230U Flatbed Scanner Questions & Answers
After downloading drivers from Canon's site for a
I have many years experience repairing Canon scanners so here is my suggestion for you.
If you now do have the latest driver from Canon's website, here is how I install them. First unplug the cable that goes from the scanner to your computer. Now install the drivers. Then with the scanner powered on hook the cable back up to your computer again. A window will pop up on your screen saying a new device or driver is being installed. Once this process completes I then reboot (restart) the computer and you should be able to scan again.
I hope this helps you out.
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Have lost the cable that connects to computer.
The round socket sounds like the power port, and the square one should be the USB as you thought.
Please respond with the scanner make/model and one of us can verify the connections required.
Joe
When i scan a photo it comes out a solaesied
it seems like the ccd scanning engine is having problems now if the scanned doc is always green in color then yes it is time to buy a new scanner, i think HP scanners are better , and also mustek its an economical brand as well but look for vista and windows 7 support in it
pls rate me generously if u like my response
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
Scan drivers not installed
Did you receive a driver with your printer? If not you need to have one in order to install the software for the printer, in order for it to work properly.
