20 Most Recent
Canon CanoScan LiDE 80 Film Flatbed Scanner Questions & Answers
I own a CanoScan LiDE
Hi j_drkotynek,
You will be able to download all the software and the driver included in your setup utility CD-ROM for your CanoScan Lite 20 on this
link. Just select your corresponding OS.
Hope this helps.
Thank you for using FixYa.
My 3 year old spilled
should be a few screws underneath, maybe some plastic latches where you will need a flat screw driver to pry open.
Canon Lide 80 Lock Switch error message.
Had the same problem as you but was able to fix it. I basically plugged it in and out while switching the lock switch until it worked. Here is my theory:
The scanner strip got stuck further into the glass instead of tucked in behind the plastic, and i couldn't use the block switch (it was stuck)
When you plug the scanner in it moved a little, i would then be able to lock the switch.
I finally locked it into the position the furthest back, then unplugged it turned the switch to unlock and plugged it in, it worked.
My explanation is a mess but hope it helps you.
I cannot make my Canon Lide 80 work in my Toshiba
have you installed latest .net framework, this may help, also did you install Everything as Administrator? Also "Run" all .exe's as Administrator too. If Win 7 on a 64bit system, remember to turn OFF Digital Driver Signing, at boot time by pressing F8, & disabling it there every time you boot the PC. That feature MUST be disabled to install it too.
Have no installation disk for canon lide 80
An error message popping out saying:
release the lock switch, deatach the I/F cable and receoonect.
scanner driver will be closed.
Code: 2,179,0
I have unlocked it and recoonect the cable. but my scanner cant seem to scan through it.
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
