20 Most Recent Yamaha Diesel Generator Edl5500dvs / Kubota G-5500s Questions & Answers
Remove the cover, and take off the broken cord, replace it with new.
Yamaha... | Answered on May 20, 2018
Check oil level and cooling air flow past the cylinder. Are there foreign material like leaves in the air intake?
Yamaha... | Answered on Mar 17, 2018
It should be stated on the id plate.
Yamaha... | Answered on Feb 21, 2018
Probably find that the carburetor jets are a bit clogged. Remove and soak in carburetor cleaner and then blow out with compressed air. Or alternately get a very fine drill set and clean, but be careful if choosing this method. Also clean the air filter. cheers
Yamaha... | Answered on Feb 19, 2018
You may find the following documents helpful for troubleshooting and parts. I use www.arcolawn.com for parts but any reseller can assist you. This model does have an adjustment on the AVR behind the main panel but please review the below manuals before adjusting. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW 0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
Yamaha... | Answered on Feb 13, 2018
voltage regulator not producing volts for the exciter windings of the alternator
Yamaha... | Answered on Jan 16, 2018
Check the brush holder for worn brushes. If they seem ok then the voltage regulator has failed.
Yamaha... | Answered on Oct 31, 2017
https://www.manualslib.com/manual/770551/Yamaha-Mz175.html
Yamaha... | Answered on Oct 19, 2017
10W-30 will be OK.
Try not to overfill it.
I use synthetic in all my small engines.
Yamaha... | Answered on Sep 15, 2017
Since most generators are seldom used, gas left in the carburetor gunks up and stops up the passages.
Take lots of pix of the assembly. Pull the carb, remove the bowl and spray carb cleaner in all the holes you see. Don't let it back spray into your eyes. Wear safety glasses. Some holes/orifices may need to have a soft wire passed thru them.
Next time you store your generator, drain the gas, run the generator til all the gas is out of the carb. If you can get to the bowl w/o removing the carb, pull the bowl and spray the bowl and underside of the carb w/carb cleaner and reassemble.
Yamaha... | Answered on Sep 11, 2017
first check the battery
Yamaha... | Answered on Jul 14, 2017
I havea PDF version but I don't know how to send it you. You may be able to download it from ths link
http://www.ownerservicemanual.com/871-owners-manual-for-yamaha-ef2000is-generator.html
Yamaha Diesel Generator Edl5500dvs / Kubota G-5500s Logo
1 questions posted
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Electrical Supplies
Most Popular Question
yamaha ef6300isde inverter generator
  • Electrical Supplies
