20 Most Recent Compaq Presario 1247 Notebook Questions & Answers
The screw is black, where are the buttons the control the brightness
You have a problem with the backlight on the LCD screen. This is similar to a very small flourescent lamp. Usually means a sreen replacement. Expect to pay about £120.00 +VAT for the Part and Labour.
1/20/2015 10:05:10 AM • Compaq Presario... • Answered on Jan 20, 2015
I have a Compaq Presario
Hello, radevroy.
A disassembly guide for your laptop can be found here. There are also instructions on how to locate and replace your wifi module.
Best of luck on your repair!
~Q
9/5/2013 2:20:35 AM • Compaq Presario... • Answered on Sep 05, 2013
2answers
Compaq Presario 1247 PC Notebook Keyboard Replacement
I don't think any screws come out of that laptop to get the keyboard out. Look at the very top edge of the keyboard for some release tabs, they are small, to release the keyboard.
10/30/2008 6:07:02 PM • Compaq Presario... • Answered on Oct 30, 2008
Cq61 will not power up light flashes 3 times
In case somebody has the same problem. Result of my investigation: * If everything is ok then the Presario CQ61 boots without battery. * HP support recommends to do a hard reset i.e. remove power supply, remove battery, press power button to discharge everything internally, connect power, press power button In my case the problem was solved by changing the AC Adapter (Power supply). Note: The led besides the power connector is not reliable. It is on with the working and faulty adapter. Note: The voltage level at the battery pins is not reliable. I had same values.
9/22/2021 1:41:52 PM • Compaq Presario... • Answered on Sep 22, 2021
Compaq Presario CQ62 - Windows 8 Pro and Acrobat Reader X1.
old PC,, Cq series. cq62-nnnnn you left off the nnnnnn cq62-100, 200 ,300 what? running mS windows 8 HP does not support W8 on this PC so that means you are on your own steam... (you , it and microsoft 100%) forget ACER this is not and ACER PC< at all, (totally different) you could reload w8 , like you did before, now all that works its login password issue, can i presume the screens look ok W8login screens? local login fails, not bios, and not windows live logins fails that is right there are 3 tiers of logins. admin , create a new account and use that or do that and ask at MS how to copy date from dead account to new account, you never said once you had data. if no data on pc, then reload 8, easy no? the newer the OS the more hard it is to get data from that dead account( new permission rules, and hard to do) ask best i can tell, lacking your full model number teh CQ62-400 (newest) had only Windows 7 so how did w8 get there, from whome, and what media. and what install methods. from MS CD? or MS ISO, or from ebay hackers disks/ what? here are the ways, (not data recovery) http://www.pcdied.com/passwords.html
9/10/2017 1:44:07 PM • Compaq Presario... • Answered on Sep 10, 2017
My Compaq Presario CQ60 won't connect to wireless internet.
how'd you do 2012 post then 2017, shocking. some one needs new clock battery , LOL
8/30/2017 11:43:01 PM • Compaq Presario... • Answered on Aug 30, 2017
N OK sound after upgrade
check o see if your sound driver is compatible with new software operating system.
2/28/2016 3:15:25 AM • Compaq Presario... • Answered on Feb 28, 2016
What key combontion to turn on wireless capability
Find your model number near the serial number. With that number go to the following link and enter it. This link is for HP's support website. You can find everything about your PC, replacement parts, Drivers, Manual. HP Troubleshooting
6/10/2015 12:52:27 AM • Compaq Presario... • Answered on Jun 10, 2015
Compag presario 700 cm2130
Please ask a question so we may help you.
2/2/2015 7:54:55 PM • Compaq Presario... • Answered on Feb 02, 2015
Fix zif connector
Oh dear you have broken this and will need to send it off to be fixed.
1/20/2015 10:02:12 AM • Compaq Presario... • Answered on Jan 20, 2015
No response frome safe mode
Won't load in safe mode?? What's your operating system? Has the hard drive been formatted?
10/2/2014 11:55:48 AM • Compaq Presario... • Answered on Oct 02, 2014
How do i factory restore my compac persario cq5602f
1. Turn off your computer. 2. Press the power button to turn your computer on. 3. Hit F11 a few times quickly, while the launch screen is still up. This will launch the Recovery Manager. (If you see the Windows 7 boot logo, you've missed your chance and need to restart your computer and try again from step 2.) 4. On the left side it will say "I need help immediately". Underneath that there will be an option that says "System Recovery". Click on that. 5. There will be an option to either back up your files before restoring, or to recover without backing up your files. In my case, I'm recovering without backing up my files. 6. It will tell you to make sure all devices are disconnected from your computer. Make sure they are, and then click "OK". 7. There will be a "Welcome to the Recovery Manager" screen. Click "Next". 8. It will begin to reformat your partition and to reinstall the Windows 7 setup files. Once it's done doing that, click "Next". You'll be brought to a page saying "Recovery is Complete". After that all you need to do is reboot, and it will bring you through the wizard to set up Windows 7, just like on a new computer! Good luck :)
8/14/2014 4:23:16 AM • Compaq Presario... • Answered on Aug 14, 2014
Presario cq40 620la
THIS IS NOT A PROBLEM THAT NEEDS to be asked on here as there are so many stolen laptops about ,ull need to go to a repair shop with proof of purchase or something that is on your system that only yourself could identify , to regain access to your laptop..
6/12/2014 8:04:47 PM • Compaq Presario... • Answered on Jun 12, 2014
Toshiba c855 screen went black
Try to reinstall windows formatting your Hard Drive... It seems to be an windows crash, or some software.
5/14/2014 8:00:59 PM • Compaq Presario... • Answered on May 14, 2014
How to fix Phdisk
Drive is formatted with wrong file system. The files you're trying to copy are too big
4/14/2014 12:23:31 AM • Compaq Presario... • Answered on Apr 14, 2014
Compaq Presario 1247 Notebook Logo
5 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
screw black buttons control brightness
  • Computers & Internet
