20 Most Recent Compaq Presario 2170US Notebook Questions & Answers
I've installed Win 8 twice so far, and couldn't wait to get rid of it within days. So, I would say start by backing up your files, because the roll back or possible failure consists of a clean wipe. Second start checking if your hardware is Win 8 ready. No sound, a lousy display, or not being to connect to the internet is the most common problem for rolling back. Then consider what applications you absolutely require and will they run in Win 8. As for Win 8 upgrade install, you get it directly from the net via MS web site for 40 bucks. The full install is readily available at most retailers.
Here are the links:
http://www.microsoft.com/en-us/windows/compatibility/win8/CompatCenter/Home
http://windows.microsoft.com/en-US/windows/buy?ocid=GA8_O_WOL_DIS_ShopHP_FPP_Light
Good Luck
Compaq Presario... | Answered on Mar 09, 2016
Can you post some photos of that?
Compaq Presario... | Answered on Jan 01, 2014
You need to get a new laptop charger. Just buy one from amazon,ebay,bestbuy or a prefessional online store, such as chargerbuy.com.
Compaq Presario AC Adapter
Compaq Presario... | Answered on Nov 01, 2012
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Compaq Presario... | Answered on Oct 01, 2012
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=326349
I hope this helps and I hope this is the correct laptop you have posted.
Compaq Presario... | Answered on Aug 19, 2012
Try this:
Reboot you PC into SAFE WITH NETWORKING:
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu".Use your arrow keys to move to "Safe Mode With Networking" and press your Enter key.
To get into the Windows Vista and Windows 7 Safe Mode With Networking, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu"Use your arrow keys to move to "Safe Mode WithNetworking" and press your Enter key.
Log into the Administrator account(password may be rquired)
Once you're in Safe mode with networking download:
rkill.exe save to your desktop and double click.A command prompt window will flash and its done.
Then download Malwarbytes:
http://www.bleepingcomputer.com/download/malwarebytes-anti-malware/dl/7/
Once Malwarebytes has been installed run a full scan
How to run a Full scan with Malwarebytes:
https://lbis.kenyon.edu/helpline/antivirus/malware_scan
Note:
If your PC does not shut down in safe mode it sounds like Malware.
Compaq Presario... | Answered on Aug 10, 2012
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Compaq Presario... | Answered on Jul 02, 2012
My 2170US does not have built in wireless like some of the other HP or Compaq models of the same vintage. Buying a mini pci wireless card wont make the wireless work. You will need a wireless card for the pcmcia slot on the left side of the laptop then your wireless will work. If there is an issue with the pcmcia slot a cheap work around is to buy a usb. based wireless card and use one of the two usb.slots in the back. It's not high speed usb.2.0 so it may run a little slower. As long as your pcmcia slot works just install the the card that you can buy even at walmart install the software and your wireless should be up and running. Its an old laptop and not worth spending a bunch of money on when new or used much better machines are out there.
Compaq Presario... | Answered on Jun 06, 2012
If the fan is not working, then take the laptop apart and replace the fan. A non working fan will cause your system to overheat and shut down.
Compaq Presario... | Answered on Jun 01, 2012
Hi
COMPAQ PRESARIO 2170US laptop does not have a VIDEO CARD.THE VIDEO GRAPHICS CONTROLLER is BUILT IN to the MOTHERBOARD also known as INTEGRATED VIDEO GRAPHICS
Compaq Presario... | Answered on Dec 26, 2011
it is most likely an embedded chip on the motherboard , not an actual video card.
Compaq Presario... | Answered on Dec 16, 2011
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Compaq Presario... | Answered on Nov 04, 2011
ebays lokkin good
Compaq Presario... | Answered on Jul 11, 2010
hi
i would request you to follow these steps .....
1st click on to start go to run and in run type devmgmt.msc.
then click on to ok ,once you have done that it will give you a window named device manager.
then click on to the plus sign of sound and video ...and check wether you have any exclmation mark ,,,if you have that then it means that their is some problem with the drivers and u need to reinstall the driver either by a help of a cd or from internet ,,,if you donot have an exclamation mark then their is a problem with sound port of the computer .....if face any problem while doing these steps u can contact me on fixya
Compaq Presario... | Answered on Sep 16, 2009
Since there are two diferent V5000 and you dident tell us whitch one you have il give u both models, chose the one you have and download the drivers u need.
Compaq pressario v5000
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=499847&lang=en
Compaq pressario v5000T
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=1832426&lang=en
Compaq Presario... | Answered on Nov 20, 2008
Try hitting enter with no password.
Compaq Presario... | Answered on Jul 07, 2008
sounds like a uProcessor or memory fault to me..that sort of board wide failure is mostly due to a memory issue..
Compaq Presario... | Answered on Mar 05, 2008
Compaq Presario 2170US Notebook Logo
34 questions posted
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
no wireless signal presario 2170us model
  • Computers & Internet
