20 Most Recent Baumatic 24 in. BFD60SS Free-standing Dishwasher Questions & Answers
kick it it works 4 me
Baumatic 24 in.... | Answered on Jan 09, 2011
this happened with mine and it turned out that the top shelf was too low, so this meant the spinning arm was being stopped by my plates. When the machine is fully loaded check that the spinners can move freely. if they don't then you can move the top shelf up a level. hope this helps
Baumatic 24 in.... | Answered on Oct 15, 2010
Hi.
E4 is overfill. This dishwasher has overvill protection.
Disconnect power and remove water from the inside using bucket and sponge. If problem occurrs frequently call service, the overflow protect device may need replacement. Service number is listed on manual.
To remove water use sponge and bucket. Ensure that power is off. On some model you need to remove the fascia panel at the base of the dishwasher, on front side. Use a screwdriver to remove panel; on others you dry water only from inside the tub
Baumatic 24 in.... | Answered on Sep 24, 2010
turn power off 20 min then back on
Baumatic 24 in.... | Answered on May 30, 2010
repLace water inlet solenoid
Baumatic 24 in.... | Answered on Apr 26, 2010
Pump is Jammed
Baumatic 24 in.... | Answered on Jan 31, 2009
Shows ERR 4 on dispaly panel. what should i do?
Baumatic 24 in.... | Answered on Sep 10, 2008
The dishwasher should heat the water to about 50 C as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water and waiting for the water to reach the temperature. In your case it look like the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. Another possible is that the timer unit is defective (this is the worse case because of its cost !!!!)
Baumatic 24 in.... | Answered on Jun 18, 2008
Is the water draining out of the machine? if not does it drain when you lower the pipe to the floor, if it does you need a new pump, if it doesn't you have a blockage.
Baumatic 24 in.... | Answered on Nov 27, 2007
It obviously has leaked water on the connections underneath, Lean the dishwasher back and see if any water comes out the bottom, then leave it standing for about a week to dry out and hopefully it should be ok.
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Baumatic 24 in.... | Answered on Nov 05, 2007
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
40 questions posted
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Baumatic Dishwashers
Most Popular Question
baumatic bad6002
  • Dishwashers
