20 Most Recent
Honeywell 2000 Watt Inverter Generator Engine HW2000i Questions & Answers
Need user's manual
crank run 2 min.cut off no fire from coil 24 hour later crank run 2 min
Coil is bad in my hw2000i
Go on line to the Honeywell website and check out users manuals. They probably have a download you can get!
Can we add a dimmer switch to Honeywell ceiling fan AC552
If the lights are on a separate switch then yes. If the motor and lights get power from the same circuit, then no. The motor cannot be run on a light dimmer for long before it will burn out. Installing an aftermarket remote control will solve the problem.
10/13/2018 6:54:28 PM •
Honeywell...
Answered
on Oct 13, 2018
Honeywell generator HW2000i Bought it cheap and
I would test the coil by removing it from the circuit, and attaching a properly gapped spark plug to the secondary, then apply and un-apply 12 volts to the primary. If you get a good strong spark on the spark plug tip each time you apply or remove the 12V, then you know that the coil is OK. This doesn't give you a measurement, but you don't know what the voltage is supposed to be anyway.
You might also try measuring the resistance across the primary and across the secondary and compare these numbers to a known good coil (anything similar should be in the same ballpark). Make sure to do that with the coil removed from any other connections and short the terminals together to remove any residual charge before you try to measure the resistance.
I hope this helps,
good luck
Al K
9/22/2018 7:55:46 PM •
Honeywell...
Answered
on Sep 22, 2018
