FixYa.com
Compaq 80-Watt Power Supply
All Products > Compaq > System Power Supplies
Problems with Compaq 80-Watt Power Supply?
Search inside Compaq 80-Watt Power Supply Knowledgebase
Troubleshooting and Support
Solved Problems for Compaq 80-Watt Power Supply RSS Feed Post a New Problem
screaming fan
hi, hope u can help. i have an hp compaq d350 with a screaming fan. it sounds like some sort of aircraft taking off when...
2 Solutions
150 W ATX Power Supply HP-150SS
how can start this whitout pc ? This is not a normal psu , is a DELL.
1 Solution
idle problems
I have a yamaha 650 V-Star Custom. I am having trouble setting my idle above 1000rpms. The bike cuts off. The only...
2 Solutions
Emergency brake handle "sleeve"...
I own a 2007 Nissan Maxima and I would like to remove the emergency brake "sleeve" and reinstall it !!! The EB...
1 Solution
cannot get into bio settings
Hi i cannot get into the bio settings i push f2 before windows load and it does not work so am i pushing the right...
1 Solution
NEC Versa M320 cmos problem!
I have an NEC Versa M320 Laptop which i am trying to clear the cmos battery on or try and change the cmos battery on!...
2 Solutions
gateway desktop troubleshooting
something happened to my e3200 desktop. when i made the power on nothing happened but the online connection light is on....
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Wattage80 Watt
Dimensions
Weight5 lb.
Compaq Contact Information
Main support number800-474-6836, 800-652-6672
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
