20 Most Recent
Compaq 120694-101 Motherboard Questions & Answers
I have been given a
Check the bottom of the front cover of the tower. If not located there then try the side of the PC below the COA sticker (Windows sticker with a hologram on it). Finally, if you are able to get the PC online you can use the HP web site to try to automatically detect the model number. If all else fails you can simply browse their web site under the type of tower, Presario, etc.
7/10/2011 1:28:27 AM •
Compaq...
Answered
on Jul 10, 2011
I reinstall XP SP-2
if you computer came with a motherboard disc all the drivers could bne on it
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-
2112_4-91313.htm
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
3/21/2011 3:12:45 PM •
Compaq...
Answered
on Mar 21, 2011
Compaq 120694-101 Motherboard would like to totally upgrade
Your PC case will hold any atx motherboard with 4 or less expansion slots. Just about everything made now will fit. You will have to replace your power supply if it still has the standard factory unit installed. The newer boards require an ATX power supply with the additional 4 pin plug for extra power to the CPU. Go to newegg and look for combo deals, they run them all the time. Here is a gigabyte board that is very nice.
GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard
I hope this solution helps you out.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
6/18/2009 3:22:02 AM •
Compaq...
Answered
on Jun 18, 2009
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
