20 Most Recent Baumatic B904SS Stainless Steel Electric Double Oven Questions & Answers
Remove element
spares4appliances has a good video
2/26/2015 7:27:47 PM • Baumatic B904SS... • Answered on Feb 26, 2015
Putting the glass back in after cleaning
Smooth on the inside.
2/26/2015 6:16:16 PM • Baumatic B904SS... • Answered on Feb 26, 2015
Front door as come away
Do yu mean the front door has pulled off it's hinges on one side or both ? if you hold the door on a angle about 12" open then press down towards the floor it will go back into place , if not you may have bent the hinges and the will have to be replaced
12/18/2011 12:47:45 PM • Baumatic B904SS... • Answered on Dec 18, 2011
I have a Baumatic double oven and the main oven
It could be a burnt wire or loose wire. test the wires for amps with a electric tester
1/24/2011 6:17:28 AM • Baumatic B904SS... • Answered on Jan 24, 2011
Temperature lights stays on an oven is overheating
From the symptons described, I would say that the thermostat is faulty that controls the oven temperature, normal procedure is replace the faulty thermostat.
11/30/2010 8:08:02 PM • Baumatic B904SS... • Answered on Nov 30, 2010
Baumatic bottom double oven does not work, both
Have you set the clock right, ovens wont work if clock in auto mode
regadrs
richard saupe
appliance repairman Colchester
3/14/2010 2:21:41 PM • Baumatic B904SS... • Answered on Mar 14, 2010
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
5/17/2009 12:04:37 PM • Baumatic B904SS... • Answered on May 17, 2009
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
1/17/2009 2:16:34 PM • Baumatic B904SS... • Answered on Jan 17, 2009
Fan oven not heating up
If fan is working then the element has probably gone
11/30/2008 3:30:15 PM • Baumatic B904SS... • Answered on Nov 30, 2008
Baumatic BT2750SS Cooker. Main oven in conventional mode only heats up to 110 and fan comes on when it shouldn't. The fan mode doesn't work?
Check the elements for continuity. Some ovens will do strange things if one element fails due to shared returns. https://www.google.com/search?q=baumatic+bt2750ss+checking+element ..
5/14/2023 4:50:43 PM • Baumatic Ovens • Answered on May 14, 2023
Baumatic B904SS Stainless Steel Electric Double Oven Logo
30 questions posted
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
View Most Popular
Baumatic Ovens
  • Baumatic Ovens
Most Popular Question
baumatic bottom double oven not work
  • Ovens
