20 Most Recent Baumatic B604SS Stainless Steel Gas Single Oven Questions & Answers
https://www.manualslib.com/brand/baumatic/oven.html
check this web site for your installation manual. this should answer this particular question.
Baumatic B604SS... | Answered on Aug 05, 2017
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Baumatic B604SS... | Answered on Mar 19, 2010
Hi there you need to change the ffd on your oven FFd stands for flame faliure device. its like an temperature controlled switch. it is located in the oven and this device is what lets the gas go through once it has reached a certain temp. It must only be done by a corgi qualified engineer and to be honest your loooking at about 100 pounds.
Baumatic B604SS... | Answered on Oct 10, 2006
DID YOU RECENTLY USE THE SELF CLEANING FEATURE . IF SO IT IS DUST FROM DOING THAT .
Baumatic Ovens | Answered on Mar 31, 2019
Where can I find a circuit diagram of the pcb to check the connections? Try contacting Baumatic.
Baumatic Ovens | Answered on Mar 01, 2019
Google (baumatic)(b600)(manual) without parens.
Baumatic Ovens | Answered on Feb 28, 2019
this is usually the door not in place correctly or a broke ndoor hindge
Baumatic Ovens | Answered on Feb 02, 2019
Does this happen after you have used the oven and switched it off?
Some ovens have an overrun on the fans to cool them down quickly and should stop after a few minutes.
If this is not the case, it will need investigating further
Baumatic Ovens | Answered on Nov 17, 2018
Baumatic B604SS Stainless Steel Gas Single Oven Logo
Popular Tags
13 questions posted
Top Baumatic Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Pie-man
Pie-man
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
View Most Popular
Baumatic Ovens
  • Baumatic Ovens
Most Popular Question
only just installed baumatic single
  • Ovens
