20 Most Recent Dewalt DW716 12 inch Double-Bevel Compound Miter Saw Questions & Answers
Dw716 sounds funny
The brushes should not make any sound. It sounds like it could be the armature bearing.
3/10/2013 4:33:30 PM • Dewalt DW716 12... • Answered on Mar 10, 2013
How to find a manual to dewalt bs 1310
How to get manual of DeWalt bs 1310??
2/19/2024 2:48:40 PM • Dewalt Saws • Answered on Feb 19, 2024
I have a Dewalt radial arm saw its a model GE68 ser no. 102395 do not know the year or hp. its a 3 ph motor. and its 16 in.
https://originalsaw.com/saw-information-resources/dewalt-radial-arm-saws/
11/17/2023 3:04:59 PM • Dewalt Saws • Answered on Nov 17, 2023
Dewalt DW788 scroll saw the blade clamp on the bottom throws the blade to the far right and is hard to get tightened.
It sounds like a design issue. Contact their Support line and ask if there are any recalls or improvements for blade alignment. https://www.dewalt.com/product/dw788/20-variable-speed-scroll-saw Yes, looks like a few issues! https://www.google.com/search?q=Dewalt+DW788+scroll+saw+blade+clamp+issues ..
11/10/2023 11:20:11 PM • Dewalt Saws • Answered on Nov 10, 2023
Makita 10" ls1030 not cutting square vertically.
bent --blade--arm-//bearings -blade shaft --shim or holding plate and bolt ///arm --shim--washer - bushing -bolt worn or damaged
3/30/2023 12:28:40 PM • Dewalt Saws • Answered on Mar 30, 2023
Should i take apart Dewalt flexvolt battery after it was wet then in rice .
The battery is likely to be fine, but what about the electric motor in the saw, in rice as well? The only thing that tends to get damaged is electronic board components. Rice only works well if it was warmed first, silica gel packs are better. A couple of days should be good, but my advice it open it up straight away and dry with a hairdryer or heat gun.
2/11/2023 1:42:41 AM • Dewalt Saws • Answered on Feb 11, 2023
DeWalt Flexivolt Mitre Saw.
It is likely that the trigger switch on your saw is faulty and not allowing power to flow to the motor. You may need to have the switch repaired or replaced by a professional. In the meantime, you may not be able to use your saw until the issue is resolved. images-undefined-undefined-0_14.jpg
2/8/2023 6:19:57 PM • Dewalt Saws • Answered on Feb 08, 2023
Changing my blades on a DeWalt 735.
The cutterhead is now exposed. If the eight screws in the cutterhead clamp are not visible, use a piece of scrap wood to carefully rotate the cutterhead (Fig. S) until the screws are accessible and the cutterhead lock lever18engages. This will prevent further rotation of the cutterhead as you change the knives
12/8/2022 8:54:53 PM • Dewalt Saws • Answered on Dec 08, 2022
Replacement antenna for a dewalt radio model dw 911
notify dewalt
9/6/2022 6:22:06 PM • Dewalt Saws • Answered on Sep 06, 2022
Dewalt miter saw DW705 sparks when I release the trigger
Replacing the brushes did not prevent eventual failure of the motor. Possibly the windings are staring to short.
5/7/2022 6:43:02 PM • Dewalt Saws • Answered on May 07, 2022
I need the belt size of a Dewalt Dw 775Qs
I can't even find a part number for this in Dewalt manuals much less the size of such. There are instructions for measuring belt sizes on the web but that's it. No use searching the Dewalt web site for the belt in the product listings. I tried and it defies any seach I can come up with. I gather they must have some internal inventory system that only they have access to. So, that looks like a job for "customer service" 800-433-9258 Monday - Friday, 8:00A.M. - 6:00P.M. Or you can try their email form on their webpage. As I can't even come up with a parts number for the belt I'm a little shy to refer you to some replacement parts dealer whose product quality I would have no way of knowing even if I had the belt size --which I don't. It is not easy to even pull up specifications for the saw you designated and those don't list belt sizes. You would think it was a nuclear secret.
1/25/2022 8:51:34 PM • Dewalt Saws • Answered on Jan 25, 2022
Can a Dewalt Model Dcs312 reciprocating saw run on 18volts
Only if it is an 18volt motor.
10/31/2021 8:49:59 AM • Dewalt Saws • Answered on Oct 31, 2021
How do I find a corded dewalt table saw DWE7485 manual
Most Dewalt tool manuals are available at the http://www.toolservicenet.com page. The parts diagram and manual for the DWE7485 is here: https://www.toolservicenet.com/dewalt/en//Dewalt/WOODWORKING/UNIVERSAL-SAWS//p/DWE7485 . The current link to the Instruction manual is https://www.toolservicenet.com/i/DEWALT/GLOBALBOM/QU/DWE7485/1/Instruction_Manual/EN/N689972_DWE7485.pdf . I hope this helps. Cindy Wells
8/6/2021 4:47:20 PM • Dewalt Saws • Answered on Aug 06, 2021
2answers
I own a Dewalt dw304p reciprocating saw and I cannot put in a blade because the blade clamp release lever is stuck in the up position. What can I do to fix this?
I had this problem when I first purchased my saws-all from Home Depot. There is a screw at the base of the blade housing. Loosen it up a little and the blade lock should pop back into the down position.c3291d70-d20e-4116-8972-743d243e731a.jpg
8/6/2021 4:07:56 PM • Dewalt Saws • Answered on Aug 06, 2021
Dewalt Flip Over DW743 Type 2 will not switch off. Blade keeps spinning. How do I fix?
disconnect power and test for switch failure
6/2/2021 11:23:01 AM • Dewalt Saws • Answered on Jun 02, 2021
I am choosing miter saw stand. Please help me to choose between DWX723 and DWX726 Stands by DeWalt
DeWalt miter saw stand dwx723 is a choice for those who prefer not having wheels because the saw has to be removed to carry the stand. It is compact and lightweight. dewalt-miter-saw-stand-dwx723-300x266-undefined-undefined-2.jpg DWX723 DWX723 comes with brackets, it folds easily and is conveniently to transport. The ends extend to support up to a 16 foot piece and come with two supports So the DWX726 rolling stand is a great alternative to the units on legs (read also Best Miter Saw Stand Reviews: Portable, With Wheels, Rolling). But it is a beast and weighs in at over 60 lbs on its own (twice the weight of the DWX723). DeWalt DWX726 stand
4/29/2021 4:45:10 AM • Dewalt Saws • Answered on Apr 29, 2021
2answers
Need a wiring diagram for a DEWALT DW 744 table saw I was running fine then stopped. Took it down checked and tested everything. It all tested good. Then blow it clean out it back together. It worked fine. Get to the job turn it on and it goes to start. Then stopped again. Now I've got power to everything but the brushes. Anyone else have this problem? Saw is about 3 years old with less then 300 hrs
Considering the average domestic quality power drill has a design life of about 10 hours your saw probably isn't doing too badly. I don't have a wiring diagram but the series-wound brush type motor hardly varies regardless of it's application. These motors are electrically very noisy and a high powered version is perpetually almost at the point of self destruction and so to prevent radio frequency interference they have to be heavily suppressed and suppression also helps protect the motor from itself. Some manufacturers use discrete components for this purpose but some use a single component that is a network of capacitors and inductors, that necessarily is compact and therefore highly stressed and these do fail sometimes. As a saw doesn't usually have a speed control, all the components can be checked for continuity with a multimeter unless it is fitted with a soft start, the testing of which is beyond the scope of home testing. If everything else is found to be ok the problem is likely with the soft start (if fitted). The current usually flows through a series wound motor from the switch to a field coil, through the field coil to an armature brush, through the armature to the other brush and then through the other field coil to the neutral. There can be slight variations to this but basically the armature is in series with the field coils. If you have power to everywhere except the brushes it would suggest a break in a field coil which is very unusual... No power to the brushes would mean no power to one of the field coils which would mean you don't have power everywhere. I suggest you begin dismantling and testing again...
3/3/2021 4:55:46 PM • Dewalt Saws • Answered on Mar 03, 2021
Blade guard sticks on my Dewalt DW939 cordless saw
Jigaloo dry silicone lubricant spray.
2/28/2021 6:36:57 PM • Dewalt Saws • Answered on Feb 28, 2021
My Dewalt 718 Miter saw makes a loud metal bell ringing sound when cutting softwood. It has a new deWalt blade and when i run the saw without cutting wood it sounds fine is this Normal? Thx in advance
That is because the blade is mage of tempered steel and if you tap it when stationary, it will ring like a bell. This this is normal.
2/2/2021 4:46:39 AM • Dewalt Saws • Answered on Feb 02, 2021
Dewalt DW716 12 inch Double-Bevel Compound Miter Saw Logo
1 questions posted
Top Dewalt Saws Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Saws
  • Dewalt Saws
Most Popular Question
dw716 sounds funny
  • Saws
