20 Most Recent
Juster : SP-801 Twintower Speakers Black/Silver Computer Speakers Questions & Answers
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front.
Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord.
Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC.
Plug the speaker transformer into a surge protector and the surge protector into a wall outlet.
5
Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
