In an earlier post I had written about how to create an invisible folder. That?s a method to create a merely invisible folder with no real protection....
written by gunjansarkar
It may well be some form of virus or spy-ware. It may also be that you have too many applications running at once eg. lots of tool-bars and instant...
written by bob_computer
This is a trick to make a folder invisible. We are not going to try to hide the file anywhere. In fact the folder would be right before your eyes but...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The most common reason for slow processing speed is insufficient RAM memory. Increase the RAM, if RAM available is no more than 512MB, then it must be...
written by ginko
People often ask for the methods to fully clear the programming of their cash register so they can start again. This is especially so when they have...
written by flexion1
let the user login the computer. goto cmd via run. enter " net user" the whole list will come out containing the administrator and guest....
written by varunduggal
This will show you how to clean up your PC. With these steps, you can do a disk cleanup, defragment, remove spyware, and everything in between... This...
by wikihow
When your computer writes information onto your hard drive, it does not always write information in the same location on the actual hardware. A...
by wikihow
Electrostatic discharge (ESD) is a fancy term for common static electricity. Getting a shock from the doorknob may not hurt you much, but the same...
by wikihow
You must be able to log onto the Windows XP machine as an administrator before you can change any passwords.
Steps:
1. Log onto the computer as an...
by wikihow
This article tells you how to tighten and increase connectivity of power cables in a computer. That would cause power interruptions resulting in hard...
by wikihow
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
1500 Castro St, San Francisco, CA 94114 | 415 8266678 | Website
Castro Computer Services provides computer har... Read More
Castro Computer Services provides computer hardware and software services for small and mid sized businesses in the San Francisco Bay area. We have both in shop and onsite services to expedite job completion. Companies that need qualified on call service technicians, whether on demand or on sched...
